Old 10-22-2003, 22:20   #1 (permalink)
Member: 12697
3330 signal lose
I have one and i reflow the Hagar but stil same.....it gives coverage but lose and recovery it again everytime........
i donīt know if this model have Cobba, it had?
What can i do?
Thanks in advance.
Old 10-23-2003, 16:12   #2 (permalink)
Member: 23333
3330=3310
lose signal after 10/more sec, it can be cobba, or check litle resistor around the PA complite.
could not register 2 the network, it can be Hagar
fist, replow the BGI with some pluk
if not showing good result, try to rebal the BGI. or u can just clean the BGI, but you have 2 be careful when lifth it, so u can place the BGI without reboll
Old 10-23-2003, 16:23   #3 (permalink)
Member: 12697
Thanks for your reply...............i donīt know where is the cobba in 3330 phones.........is gives coverage and lose everytime, gives seconds but lose another time,...........when you say check litle resistor around the PA complite, how i can to check, because i can rebowling any BGA but i donīt know how to see the check voltage.. and when you say replow the BGI , you want to say to reflow the cobba (if i find it)
Thanks in advance.
Old 10-25-2003, 20:02   #4 (permalink)
Member: 39245
Thanks Meter: 43
Look at the bga Ic which have V.257. It's position beside of CCONT. Do u have service manual for that ???? Its N250.
Old 10-31-2003, 05:44   #5 (permalink)
Member: 23372
Thanks Meter: 18
try to change the p.a
Old 10-31-2003, 10:23   #6 (permalink)
Member: 42381
change flash and cobba ic both.
100% network.
or change 2600MHz power crystal.
It will work man
regards
Yuvraj Technician
Old 10-31-2003, 15:05   #7 (permalink)
Member: 42974
repair 3210
nokia 3330..13mhz lose lidar Nokia Hardware & Hardware Repair 2 07-01-2004 10:42
Nokia 3330 signal drops to zero jeanfleur Nokia Hardware & Hardware Repair 8 02-15-2004 14:20
3330 signal problem Cad Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 04-01-2003 18:40
3310\3330 signal problem !!!!!!! vule Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-16-2002 03:26
Nokia 3310/3330 Signal Problems - Help Required max8108 Nokia Hardware & Hardware Repair 8 01-24-2002 09:56
Page generated in 0.17116 seconds with 9 queries
