Old 09-13-2004, 17:44   #1 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 47
Question 33XX RAM work
Hi all,
I've faced lot of problem about reballing Flash / RAM ICs in Nokia 33xx phones. "RAM BAD" error message while Flashing I used to rehot or resolder these ICs.
In many cases reballing of Flash IC has been successful BUT reballing or even heating of RAM IC has FAILED IN ALL CASES.
I would like to know PROPER workmanship on this RAM IC. What precautions or care shoul I take.
regards
Old 09-13-2004, 18:06   #2 (permalink)
DMD
DMD's Avatar
Member: 12660
Thanks Meter: 7
@ rajunmobile
that error message is proberly from the old dct3 flasher by rolis in general that error has nothing to do with ur ram ic its normally dry joints cable etc but the error given is "ram bad" no wonder ur not coming right with the phones
Regards D.
Old 09-14-2004, 14:19   #3 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 47
@ Mr. DMD
Thanks for reply. But I tried to Flash with Rollis, Knok95, Geo etc. In all software the error message is "RAM bad".
@ Mr. azampk
Thanks for reply and picture. I measured the component is OK. I think it is an inductor and while power ON it will have @1.9 volts. do you refer any other check ?
Recently 2 boards have this problem. Both are taking Flash but not power ON. ( one is 3350 and other is 3315 ). What should I do ?.
Old 09-16-2004, 07:46   #4 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 47
@ Mr. azampk
I mean, I measured the component as per your suggestion and found in OK condition. As per my knowledge it is an inductor and it provides voltages for Flash/RAM ICs.
To all
I would like to know working on Flash / RAM ICs. It may require some special techniques which I may not have. Thanks in advance.
regards.
mr lead help, working amd64b, 2gb400mhz ram atv Cruiser Suite 3 03-06-2006 18:35
Recovering "Phone RAM is bad" - 6210 100% working Safrane Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-19-2002 15:58
DEAD Nokia 33XX with PHONE RAM is BAD gsnbhagawan Nokia Hardware & Hardware Repair 6 05-25-2002 05:15
DEAD Nokia 33XX with PHONE RAM is BAD gsnbhagawan Nokia Hardware & Hardware Repair 0 05-22-2002 23:21
Wintelsa solution 33xx,8210,88x0 GsmSolution Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-07-2001 21:46
Page generated in 0.14308 seconds with 10 queries
