3410 no ring have a 3410 with no ring the phone will vibrate but no sound i have seen with the 3310 you join pin 6 of the chip next to the speaker to the lower speaker connection to solve the problem does this work with the 3410 ? thanks mark |
Re: 3410 no ring Quote:
that case is line cut from said pin 6 ( UI) to connector for 3310,, incase if your 3410 line cut too, ofcouse it will work ! Willy |
Use it! :cool: One of the ringer pads must be conected to pin 6 of UI IC. (you can see thet in service manual). Put your multemeter in "beep mode" and soon you will know that this line is broken or not :) |
also on others side of ring connector pad, it is connect to VB ( to battery V+) check it too ! Willy |
