Old 04-20-2003, 16:33   #1 (permalink)
Member: 11482
Thanks Meter: 3
3410 no ring
have a 3410 with no ring the phone will vibrate but no sound i have seen with the 3310 you join pin 6 of the chip next to the speaker to the lower speaker connection to solve the problem does this work with the 3410 ?
thanks mark
Old 04-20-2003, 23:02   #2 (permalink)
Member: 1060
Thanks Meter: 9
Re: 3410 no ring
thanks mark
Mark
that case is line cut from said pin 6 ( UI) to connector for 3310,,
incase if your 3410 line cut too, ofcouse it will work !
Willy
Old 04-21-2003, 00:56   #3 (permalink)
Member: 14004
Thanks Meter: 6
Re: 3410 no ring
Do you have this little but very helpfull thing called multimeter?
Use it!
One of the ringer pads must be conected to pin 6 of UI IC. (you can see thet in service manual). Put your multemeter in "beep mode" and soon you will know that this line is broken or not
Old 04-21-2003, 01:08   #4 (permalink)
Member: 1060
Thanks Meter: 9
also on others side of ring connector pad, it is connect to VB ( to battery V+)
check it too !
Willy
k300 no ringing or ring wery quiet pls help alex1205 Sony Ericsson Hardware Repair 5 01-29-2007 08:11
3510i no ring, no vibra, no lights. E&D Nokia Digital Core Technology 4 ( DCT-4 ) 4 12-01-2005 22:56
8310 vibrate but no ring ( no ringer , no ringtone) and not software problem gsmnice Nokia Hardware & Hardware Repair 6 05-19-2004 17:25
6100 no ring no vibrate no illumination!!!!!!!! micmac Nokia Hardware & Hardware Repair 11 09-18-2003 11:14
3410 Not Ringing just vibrating Rebels Advocate Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-30-2003 17:28
Page generated in 0.28278 seconds with 8 queries
