-   Nokia Hardware & Hardware Repair (http://forum.gsmhosting.com/vbb/f148/)
-   -   3410 nokia charging ok but no power (http://forum.gsmhosting.com/vbb/f148/3410-nokia-charging-ok-but-no-power-185947/)
gsmwiz 01-31-2005 16:01
pls help .
i have a 3410 nokia .it charges ok and will power when charger is plugged but will not power when charger is removed.i have serviced the board and checked battery connector but no result.thanks
^PAX 01-31-2005 20:50
look at on/off button, maybe damage .change it .
Nabil3H 02-01-2005 00:11
try to flash full backup after
try to change CCONT "90%"
CyberoptiK 02-01-2005 00:17
First Update and reflow Ccont, if not ok, check this out:
http://www.directupload.net/images/050201/o9uZ3XC6.jpg
GreetZ
Nabil3H 02-01-2005 00:21
This solution if the phone not power on "if it charge only"
but in this case it power on if the charger is connected
CyberoptiK 02-01-2005 00:24
I already wrote: After check CCONT..
GreetZ
xchris 02-01-2005 01:14
1 Attachment(s)
check this...marked with red. ;)
darie cruz 02-02-2005 16:05
helpful opinion from xchris....u cud also consider to reball/replace the ccont as cyberoptik suggested
gsmwiz 02-02-2005 17:30
nokia 3410
thankx chris but what do i do with the red 'R'.do i remove completely or replace.thankx in advance
segun 02-06-2005 00:21
you should replace .......but u have to read it first
segun 02-06-2005 00:23
here is another simple way ,,,if u dont want to remove the v202 ..........just use a thin small wire and connect with ur 2.8v ..........but make sure u connect from the bottom of the switch.......and it will work 10000000%..
SALLAM 02-06-2005 00:28
gooood wooooooork
hodafone ................
gsmwiz 02-09-2005 18:24
3410 charging ok but no power
thanks segun but what switch are u referin to
gbada 02-10-2005 10:50
is it the first component in the red mark or the second one we connect with the switch
kokos 02-16-2005 10:00
what should look for when phone powers up sometimes then the switch off menu appears on display...looks like faylty on off switch but already changed several , changed the capacitor and the resistor near the rf shielding on top right... changed v202...any ideas? :)
Page generated in 0.26957 seconds with 5 queries
