Old 11-29-2003, 15:40   #1 (permalink)
Member: 6060
3410 signal loose after 5 sec.
Hi!
I have dropped 3410. Phone register in network and after 5 second loose network. It is the same in 900 and 1800 MHz. I have changed PA but problem still the same.
thanks for reply.
Old 11-29-2003, 18:09   #2 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,395
Check Antena swich & resolder cobba
Old 11-29-2003, 19:10   #3 (permalink)
Member: 41186
Change hagar and pf in the same time.Post result!!!!!!
Old 11-29-2003, 22:12   #4 (permalink)
Bohosh's Avatar
Member: 14741
Thanks Meter: 119
Try with change hagar and cobba
Old 11-30-2003, 12:44   #5 (permalink)
Member: 39601
Thanks Meter: 13
OK..
Droped means a brocken thing.., for differential diagnoses
1- If the phone feels the available networks , that means that the
rx section did not affectes.--> So we have to check Power-Ampl.,
Ant-Switch, and maybe cobba brocken balls.
2- If the phone doesn't feel the networks , that means Incomeing
Rx path---> Check Ant-pad could be brocken, Ant-Sw. could have
a brocken pins at the base of it, filter crystals, and also maybe a
brocken balls nder Hagar.
Old 12-02-2003, 09:25   #6 (permalink)
celtec's Avatar
Member: 25504
If after lost Signal U haven't beep when U push key, maybe would be FAID.
Try to update FAID or rewrite IMEI and then update FAID.
Alex
Old 12-05-2003, 07:28   #7 (permalink)
Member: 13545
Thanks Meter: 2
Check supply voltage to PA ...!!!
MrHazeem
Old 12-05-2003, 07:36   #8 (permalink)
Member: 6744
Check duplexer ....
Old 12-06-2003, 07:01   #9 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
In this case pls check Voltage out of Power IC!!!!!!!!!!!
Old 12-06-2003, 21:51   #10 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 133
and dont forget to replace rtc crystal
it is so importent.....
Old 12-07-2003, 06:11   #11 (permalink)
Hanukkah's Avatar
Member: 5246
Thanks Meter: 9
Use Wintesla and Go to RF controls and try to let your phone transmit at power level 5. If you put flashing keychain and it starts to blink then TX is ok.
Tx ok means your PA is working. If your PA is new, then you would have to check power line to PA from Bat +. Might be line cut (water damaged)
If lines are ok then your PA might not be working.
Old 12-07-2003, 11:28   #12 (permalink)
Member: 6060
I changed: CCONT, HAGAR, COBBA and RTC. Still the same problem. I'm sick and tired 'cause of it.
Please tell me on which pin is +vbat on PA.
Old 12-07-2003, 11:33   #13 (permalink)
Member: 39601
Thanks Meter: 13
The 2 mid pins ( of the for) , faceing the ant-switch.
Old 12-07-2003, 14:46   #14 (permalink)
Member: 44142
try to change the cystal ic...~
Old 12-07-2003, 16:56   #15 (permalink)
Member: 6060
The voltage is good for PA.
Which crystal ic change?
1112 imei change No signal off after 30 sec Kamijeeawan Universalbox 18 08-10-2009 07:47
8330 signal drop after few secs ... ?? TRABEL LG 4 08-16-2005 23:31
T65 reset after 5 sec misel Sony Ericsson 4 05-30-2003 00:16
No signal after 5 secs. laxxe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 03-16-2002 20:49
C25 - "wrong soft " and shutdown after 5 sec Name x1x to x45/x50 15 12-09-2000 20:24
Page generated in 0.20843 seconds with 9 queries
