Old 07-05-2009, 20:00   #1 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
n82 no any key paress
hi body i have n82 no any keypad pares i have change keypad ic but stile same do u have any other solution also i have remove near camera batten and volume batten and black resister remove but stile same !
best regards .
ikram butt
Old 07-05-2009, 20:17   #2 (permalink)
moncef5's Avatar
Member: 163515
Thanks Meter: 23
Best regards .
Ikram butt
it happend for me one time before change flex it well be ok good luck
Old 07-06-2009, 08:29   #3 (permalink)
Member: 772941
Sonork: 112
Thanks Meter: 349
yes 95% flex cable problem if you press flex connector some time it will work ( try to change nother flex cable)
Old 07-06-2009, 09:39   #4 (permalink)
Member: 729295
Sonork: hendy
halo, bisa tolong kasi tau trik jumper ic camera nokia n82
samsung c200 no any key working dashraj Samsung Hardware Repair 10 06-06-2010 14:20
Flashing N82 using MK KEY!! zoland_hole MXKEY Nokia Flasher and Unlocker (by Alim Hape) 10 01-03-2010 01:35
5610 no any key press? ..::Mr_Fone::.. Nokia Hardware & Hardware Repair 7 01-02-2009 10:19
N818gb No Any Key Paress Only On/of ..::Mr_Fone::.. Nokia Hardware & Hardware Repair 3 08-10-2008 08:40
X60 No Power Off and any Key Work !! Mierdita Panasonic 3 08-22-2005 15:02
Page generated in 0.13926 seconds with 9 queries
