07-14-2004, 06:18 | #1 (permalink) |
Insane Poster Join Date: Mar 2002
Member: 10015 Status: Offline Thanks Meter: 0 | 3510i blink and go off my 3510i after switch on, phone light on leds and after a few msec (max to 1s) switch off. Nothing appear on the display. Battery is ok, phone board tested on pwr supply. any idea? thank u |
07-14-2004, 07:35 | #3 (permalink) |
Member: 10015 Status: Offline Thanks Meter: 0 | thank U smileGSM So I need to safe the contacts in this phone, is there anyway to do it? I'm afraid that the flash is damaged, couse 3months ago I had changed flash IC. How can I test it (without flashing)? thanx |
07-14-2004, 08:39 | #6 (permalink) |
Member: 10015 Status: Offline Thanks Meter: 0 | Ok, thank U guys. So if the flash ok, and phone will work after flash new firmware, can you explain me what's wrong in my phone? I can imagine, that there is a broken ball under flash or sram or other BGA, but phone is so insecure for me. When one phone make two times the same malfuntion, is not usable for me. Thank U for ideas best regadrs |
07-14-2004, 09:21 | #7 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Serbia Age: 40
Member: 49634 Status: Offline Sonork: 100.1671023 Thanks Meter: 71 | It's a common fault in 3510i,ussualy the problem is in using GPRS,flash it with 5.25 and beware wath are you downloading from wap |
09-04-2004, 23:17 | #11 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | i have same problem, mine has broken link + to R22, i repaired it. now i can flash phone. after succesfully flashing , i cant power on the phone. When i power it just blink and powers off. any idea? i used last fw version Pali |
09-19-2004, 20:51 | #12 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | i cant power it normalny . i can only enter TESTMODE . on selftest i have this error : No signal - ST_MBUS_RX_TX_LOOP_TEST Can any1 help me with this please? Pali |
3110c after start up blink 3 times and go off | intelp3 | Nokia Base Band 5 ( BB-5 ) | 5 | 10-04-2009 15:25 |
n80 hang on nokia and go off | sonumobilewala | Nokia Base Band 5 ( BB-5 ) | 3 | 06-04-2008 17:12 |
3650 power on for secound and go off | Ian | WD2 & APE (Symbian Phones) | 14 | 12-05-2007 17:16 |
BE4 antena one bar and go OFF??? | MOBICOM | Alcatel & TCL Old Models | 7 | 10-29-2004 23:51 |
T100 blinks....and go off????? | Headmade | VLSI, Conexant, Skyworks and Old Models | 0 | 03-06-2003 14:34 |
