3510i Power off when receiving calls ! 3510i power off when receiving calls .What can be the solution? |
check battery connector check PA update firmware goodluck |
And check/try another battery! |
Although the battery is full ???? The battery is full |
Battery/// Change the battery then check uor phone will work....if not do full flash your phone. WBR Imran Khatri |
bR |
Hi There If not batt problem then check connector, if not yet then check pa, if then also no, then just flash the phone. Ok it must work but it still no, uu must reflow the circuit and then flash it. It must work. regards Ayush |
