05-26-2006, 23:41 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: ..:::algEria::..
Member: 198673 Status: Offline Thanks Meter: 8 | 3595 To 3510 (dead) i v go to make a band conversation for a 3595 .i changed all of 3 fillters and the VCO and it all ok but when i reflached it on 3510i ..........fone is becoom DEAD .the fone took MCU +PPM flach without any error . i try with many version of 3510i but no way any one have experiance in this case... thanx n adavnce |
05-27-2006, 10:44 | #4 (permalink) |
Freak Poster Join Date: Apr 2006 Location: MANILA Age: 44
Member: 254324 Status: Offline Thanks Meter: 15 | how bout a converted 3595 to 3510i keypad malfuntioned after write PM??? is this a common error?do you think those keypad could still function correctly?tnx a lot... |
05-27-2006, 12:49 | #5 (permalink) |
Freak Poster Join Date: Nov 2003 Location: batangas Age: 52
Member: 43873 Status: Offline Thanks Meter: 3 | @aimedgsm check your flash ic i think its not amd 29bds643gt with 4s at the bottom if that's the case then you must reflash your phone with 3595 flash for the phone to power up when it powered up in local mode read pm file then convert it with pm to rpl converter by monxx (thanks boss monxx) by the after backing up pm and converting it to rpl replace flash ic with amd29bds643gt flash the phone mcu, ppm, write uem with the converted rpl and post here any problem @scion yup it can be repaired just upload another pm try my attached pm file post here the result |
05-27-2006, 20:48 | #6 (permalink) | |
Member: 198673 Status: Offline Thanks Meter: 8 | Quote:
big thanx to you bro .........but im realy intresting to do it ...(my *******r ) br | |
05-28-2006, 07:14 | #9 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Treasure Island of the pacific
Member: 168090 Status: Offline Thanks Meter: 92 | @scion here's yours For 3595 converted to 3510i with keypad problem.. tested 100% working... |
The Following User Says Thank You to blu angel For This Useful Post: |
05-28-2006, 07:18 | #10 (permalink) | |
Member: 168090 Status: Offline Thanks Meter: 92 | Quote:
BR... | |
05-28-2006, 12:26 | #12 (permalink) |
Member: 254324 Status: Offline Thanks Meter: 15 | to no avail....here is the history:...that unit 3530i was originally converted by chinese gurus.it runs smoothly after they converted it in 3510i.then few months later the RF sgnal starts to fade til 1 bar in isolated places.then my first solution is to write a brandnew PM.to my surprise the keypads *****!!! im just wondering where those chinese people got their invincible PM!!!!!!! |
05-28-2006, 12:34 | #13 (permalink) | |
Member: 254324 Status: Offline Thanks Meter: 15 | Quote:
05-28-2006, 15:31 | #14 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | i am also having one problem after conversion.....i change three filters... and then i flash it with 3510i and write pm... but the problem is this that this is not detecting all networks... and one more thing that this is also losing signall.... and i have to rescan the network.. and then okay... is there any soloutins left... wot should i do....? thanks |
05-28-2006, 18:51 | #15 (permalink) |
Member: 43873 Status: Offline Thanks Meter: 3 | have you replaced the vco? for me i always convert 3595 to 3530 using the jumper method no i only put jumper on the filters and i do not replace the vco but in your case you should replace the vco with vco from 3530 try to replace it by the way converted units specially 3595 does not detect all networks because the conversion only uses single band (900mhz in 3595) to convert it to dual band is very tedious and time consuming but it can be done with some side effects |
prob converting 3595 to 3510 | i_m_dhruv2001 | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 07-11-2009 17:47 |
how to convert 3595 to 3530 | danish_teli | Nokia Hardware & Hardware Repair | 3 | 01-07-2008 08:22 |
how to convert 3595 to 3530 ? | harish35200 | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 05-17-2006 14:20 |
HOW TO CONVERT 3595 TO 3510i OR…..? | jamohaki | Nokia Hardware & Hardware Repair | 2 | 08-18-2005 07:40 |
changing 3595 to 3530 (850/1900 to 900/1800) | miq | Nokia Hardware & Hardware Repair | 0 | 08-28-2004 21:22 |
