Old 12-13-2007, 09:16   #1 (permalink)
vinay_sharma's Avatar
Member: 309398
Sonork: 100.1590052
Thanks Meter: 5,455
3650/60 New 4Blinks Solution
I recently just tried this solution for Nokia 3650/60 4 Blinks problem. I am using twister dongle. And just maybe, the supply is not enough for the phone to go in local mode when the status is 4 blinks w/o flashing it. But when i revised the cable and used a 9v batt, the local mode displayed even i didn't flash the phone.
I just did it like this:
1. Connect the cable to the 9v batt.
2. Connect it to the phone
3. Connect it to the dongle.
(at this point the "NOKIA" must be on the screen w/o the blinks, if not, just slightly press the power on button to let the "NOKIA" display.)
4. Format User Area, UI Default,..etc
5. Init Sim Locks
Old 12-13-2007, 10:10   #2 (permalink)
Member: 275352
Thanks Meter: 17
f u have a erase pm file use it, then flash the pm again, or just click erase then full flash the phone, i hope it can help this procedure to, because it work to me 100%
Old 12-13-2007, 13:45   #3 (permalink)
Member: 205157
Sonork: 100.1574537
Thanks Meter: 82
hi
are u shore it works fine
Old 12-13-2007, 13:57   #4 (permalink)
gyuszko's Avatar
Member: 8086
Thanks Meter: 180
Format user area is not enough in most cases, phone will be ok, but customer will bring it back with the same error in a few days. U must do full erase of flash becouse some "garbage" data is left in the flash area and it will make phone crazy again.
Old 12-13-2007, 14:02   #5 (permalink)
Member: 127269
Sonork: 100.1605945
Thanks Meter: 68
See My Old Postings As I Have Described So Many Times
Solution Contact Retailer 6600-3650-60/3230/7610 & 6260. king.of.gsm Nokia Hardware & Hardware Repair 0 12-12-2009 20:05
3650 net work 10000000% solution biniesh_08 Nokia Hardware & Hardware Repair 0 04-16-2009 17:03
6610,7250,3100,6600,3650/60 flash chip numbers cgsm Nokia Hardware & Hardware Repair 21 05-04-2007 12:00
3650/60 New 4Blinks Solution remylebeau Nokia Hardware & Hardware Repair 15 09-02-2006 13:13
Nokia 3650/60 pinnout schematics TetraUK UFS2 + UFS3-Tornadoflasher 1 10-20-2004 17:51
Page generated in 0.18637 seconds with 9 queries
