05-20-2004, 11:52 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | 3650 change flash ic thanks |
05-21-2004, 18:05 | #3 (permalink) |
Member: 5379 Status: Offline Thanks Meter: 0 | pretty hard to find the flash ic for 3650, could we use the same one like we always find in some version of 6510 or 8310 ? it looks just the same about size, form and number ... i think regards |
05-22-2004, 10:08 | #4 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | yes... there are 2 types of 3650 ics's. Intel and AMD (?). 3 of them must be same manufacturer, so... u cant change intel flash chip with AMD one, except you replace 3 of them. Susah ... emang susah bos |
05-25-2004, 04:35 | #6 (permalink) |
Freak Poster Join Date: Sep 2001 Location: ASIA
Member: 6569 Status: Offline Thanks Meter: 15 | I also face the same problem. 3650 was waterlogged & dead when it came to me. I reballed all the ic, uem, cpu, all 3 flash ic. after that the phone was on but imei was corrupt, so it chaged uem & everything was ok. After 2 days, phone was dead, now i can flash the phone properly but while restoring factory set it fail & phone does not get on. Pls help me if somebody has solved such problem. thanks. |
05-26-2004, 13:22 | #7 (permalink) | |
Major Poster Join Date: Feb 2004 Age: 47
Member: 51636 Status: Offline Thanks Meter: 1 | Quote:
Can you flash the phone with manual flashing? | |
05-27-2004, 08:47 | #8 (permalink) | |
Member: 6569 Status: Offline Thanks Meter: 15 | Quote:
yes sir, I can flash the phone in manual flashing with griffin. I can also flash the phone with ufs-2 also. | |
05-28-2004, 02:02 | #9 (permalink) |
Member: 51636 Status: Offline Thanks Meter: 1 | I have experience b4 that i have one 3650 with the latest UPP. When flashing with 3 different boxes of griffin,only one can success make the phone turn on. Check your UPP, is that new version? If you manage to flash your IC completely, you have no problem in UPP and Flash IC. Somemore for this type of problem, the firmware that work must be version 4.13. |
12-29-2004, 15:52 | #11 (permalink) |
Freak Poster Join Date: May 2004 Location: kediri Age: 46
Member: 65714 Status: Offline Thanks Meter: 17 | how about nokia 3660?, i try to change 3 ic flash, now my nokia dead. i try the solution like above, not work dude In some chase this solution work for me, but sometimes i got a trouble in nokia wd2, Is it 1st ic flash bring the IMEI number? plz explain for these 3 ic flash send your answer to my email [email protected] WD2 sulit |
12-29-2004, 18:12 | #12 (permalink) |
Freak Poster Join Date: Mar 2002 Location: near you Age: 44
Member: 10528 Status: Offline Thanks Meter: 4 | same in n-gage 6600 3650 3660 u must change the 3 flash ic and be carefull you must install the ic`s (heat it under board ) .... flash the phone ..... format user area .... all OK. |
k800 after change flash ic how to flash ...? | jimmyyew1981 | DreamBox | 7 | 03-16-2009 18:19 |
how to flash k500 with a newly change flash ic? | ryumahon | Cruiser Suite | 1 | 04-23-2006 09:31 |
3510 changed Flash IC >>> IMEI full of ??? | DJ_Andy | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 09-14-2004 22:03 |
3310 after change Flash Ic | Zabra | Nokia Hardware & Hardware Repair | 11 | 08-05-2004 11:46 |
change Flash Ic | hooi76 | Hardware Repair by brands | 0 | 12-14-2001 11:41 |
