11-13-2004, 07:17 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: India Age: 48
Member: 8587 Status: Offline Thanks Meter: 4 | 3650 + MMC problem. This 3650 is not working only with memory card. The handset works normally without memory card, but when we put in the memory card it starts behaving wild like it throws error messages like "system error", "app closed"...... I have tried this with four memory cards, tried upgrading the software nothing happens. Its all the same even now. Intresting thing is without any software in the memory card the handset is ok. Once we start loading the software after a while the handset behaves wild. Any solution will be helpful. Thanks for replying. Regards |
11-13-2004, 13:58 | #2 (permalink) |
Freak Poster Join Date: Jul 2004 Location: m'sia Age: 42
Member: 74212 Status: Offline Thanks Meter: 5 | have u try to format memory card?use the phone to format memory card.i have this problem before it,but just used the phone to format memory card is ok,try it!!! |
11-13-2004, 22:54 | #3 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Olympia
Member: 44950 Status: Offline Thanks Meter: 10 | do what mtech6928 said format the memory card in the phone... normally 3650 having trouble with application installed and sometimes with the memory card if it is corrupted or damaged... |
11-14-2004, 07:23 | #5 (permalink) |
Member: 8587 Status: Offline Thanks Meter: 4 | I have tried all of that mates but nothing seems to work. Erased the full flash area with griffin and ufs and flashed the phone with the same. Format the memory card with the phone and the mmc reader. For a while the phone seems to be ok but when I try to load games or applications after some time it starts giving problem. Thanks for the reply mate. Regards. |
11-14-2004, 09:43 | #6 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 52
Member: 54993 Status: Offline Thanks Meter: 47 | Check for any contact of MMC for open - short. Clean it well. Whenever you try to load the application, game it behaves like mad. So data read pins of card reader may have damaged. check it well. Good luck... Regards. |
11-14-2004, 10:14 | #7 (permalink) | |
No Life Poster Join Date: Oct 1999 Age: 48
Member: 4201 Status: Offline Thanks Meter: 6 | Quote:
Best regards, Irinel | |
11-16-2004, 08:54 | #11 (permalink) | |
ADSP flash you can make only with J.A.F,GRIFFIN,PRODIGY. Best regards, Irinel | |
11-17-2004, 10:35 | #13 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: Milano, Italy Age: 37
Member: 62336 Status: Offline Thanks Meter: 115 | Quote:
11-17-2004, 10:59 | #14 (permalink) | |
best regards, Irinel | |
3650 MMC problem | GSMhonest | Nokia Hardware & Hardware Repair | 6 | 08-28-2008 12:13 |
3650 flashing problem, HW problem | Trixxie | Nokia Hardware & Hardware Repair | 8 | 07-05-2004 10:54 |
3650 MMC Password | sp00ner | WD2 & APE (Symbian Phones) | 4 | 10-24-2003 07:45 |
MMC problems again please can........ | robbiesl42 | x1x to x45/x50 | 3 | 02-04-2003 17:50 |
Mmc Problems!!! | robbiesl42 | x1x to x45/x50 | 5 | 02-01-2003 16:51 |
