07-14-2007, 18:18 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: India(Sikkim)
Member: 311436 Status: Offline Thanks Meter: 38 | 50% not charging solution |
07-14-2007, 20:41 | #2 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: guangzhou,CHINA & delhi,INDIA
Member: 399779 Status: Offline Thanks Meter: 125 | Quote:
that is only .5% not 50% ...........keep it up regards PUNEET14884 | |
07-15-2007, 07:26 | #3 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | Many cases of not charging can be solved by refixing UEM ( caused by drop ) and may due to faulty components on the charging way and those on the BSI track to uem try to measure the charging current in the faulty set and just compare it with that of a working set here you can see the differance then you can fix the cause check this and post your comments good luck regards, NEIL |
1100,3310,2300,2100,last not charging solution | koolzykoller | Nokia Hardware & Hardware Repair | 72 | 12-04-2010 10:30 |
1100 not charging solution? | etcelfon | Nokia Hardware & Hardware Repair | 4 | 07-30-2008 16:20 |
K300 Charging but not Charged Solution | wsw243 | Sony Ericsson Hardware Repair | 0 | 07-27-2007 02:28 |
V980 not charging SOLUTION :) | et.com | Motorola Hardware Repair | 3 | 01-04-2007 20:35 |
5140 nokia not charging solution | karouk | Nokia Hardware & Hardware Repair | 0 | 06-04-2005 01:06 |
