5110 charging problem when i connect charger to 5110 - at display i will see battery bar, but after 2-3 seconds (when charge bar must start to going up) phone doing "BEEP" and power off. In service manual i haven't chapter about charging. May be any1 know where prob. can be ? |
not charging Hi -=ELF=- Try Checking http://www.id2.cz/service_manuals.htm they have the full level 3 service manual Later D.;) |
i was download service manual from these site - this manual haven't chapter about charging :( , only scheme problem not in CCONT and not in NMP70165 - changed, but prob not solved. |
try checking battery terminals first if its ok try changing the resistor with a k letter found in the bottom of the pcb near MAD gud luck:) wamir |
There a common problem with 5110 - you must take a look for damaged capacitor in charging circuit! |
check V100 he must be >20KoHm when is <20 phone says beep and stop charging |
