01-27-2002, 10:50 | #1 (permalink) |
No Life Poster Join Date: May 2001
Member: 4675 Status: Offline Thanks Meter: 7 | 5110 no speaker and mic, but ok in headset. |
01-28-2002, 15:18 | #2 (permalink) |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | EASY SOLUTION: REMOVE BUFFER ( 5 LEGS ) IN FRONT OF HANDSFREE CONNECTOR,IT WILL FIX YOUR PROBLEM BUT YOUR HANDSFREE WONT WORK OR YOUR PHONE WONT CONNECT TO PC. |
10-09-2002, 17:41 | #4 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | i have remove Headset connector and also replace 5 legs IC ( both of them) the problem still : "HEADSET". I try to wash with thinner, still no result .... Any help ?? b.r |
10-09-2002, 18:17 | #5 (permalink) |
Freak Poster Join Date: Aug 2002 Location: __inside__ Age: 41
Member: 14792 Status: Offline Thanks Meter: 1 | hi eureka8888 and cellm@n.. first have a look at caps. and resistors around the board to board connector.and look if the connectors bent or dusty..after that look at the COBBA&MAD i.c. if there is opened pin of them..if they are all o.k.the pcb may be the reason...so follow the diagrams from service manual NSE_1..and solve the problem by connecting wire.. just try...__jero__ |
10-10-2002, 21:55 | #9 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | my problem solved by checking R256, R257 and also 261. . . Traced it, and finnally problem found at C255 Short Circuit. Test it to ur mobile .... may be have the same solution... BTW, my mobile was WATER DAMAGE BR |
Samsung E600 no speaker & mic, but ringtone's fine | lokkinho | Samsung Hardware Repair | 1 | 08-03-2007 09:07 |
no speaker and mic SE T00 | .::Moby World::. | Sony Ericsson Hardware Repair | 4 | 11-30-2006 00:21 |
a88 no speaker and mic sound | SATISH | Samsung Hardware Repair | 4 | 02-17-2006 15:54 |
speaker and mic not work in 6610 | mido&mido | Nokia Hardware & Hardware Repair | 4 | 09-19-2004 18:38 |
Ericsson T28 No Speaker and mic | unoche | Sony Ericsson Hardware Repair | 6 | 11-16-2002 15:28 |
