03-10-2002, 04:34 | #2 (permalink) |
Freak Poster Join Date: Feb 2002 Location: www.gsm-support.co.uk Age: 53
Member: 9302 Status: Offline Thanks Meter: 1 | There is charging fuse. It's probably gone. Try to locate it and replace it. If it can help you its the firs element connected to the charging pins. |
03-10-2002, 20:51 | #5 (permalink) |
Insane Poster Join Date: May 1999
Member: 41 Status: Offline Thanks Meter: 5 | You must check a few thinks: 1. the four battery pins are ok and also soldered ok 2. near the fuse there is a 1uf/35v capacitor -replace it 3. there is also a vdr near there -replace it if short circui. |
03-11-2002, 01:11 | #6 (permalink) |
Freak Poster Join Date: Aug 2001 Location: GSMLAND
Member: 5764 Status: Offline Thanks Meter: 2 | charging problems are solved very easy on most of the cellphones just take one WORKING board and multimeter and compare the resistance between them and you will see that nothing can be easier, that repairing charging faults |
5110 not charging | c0c0 | Nokia Hardware & Hardware Repair | 7 | 04-05-2007 02:36 |
5110 not charging.. | sergo_zmeia | Nokia Hardware & Hardware Repair | 5 | 09-14-2004 14:43 |
5110 not charging | gsmsalers | Nokia Hardware & Hardware Repair | 6 | 07-30-2003 22:43 |
5110 Not Charging | Black-Axe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-17-2002 22:33 |
NOKIA 5110 not charging | liviu.m | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 05-26-2002 22:41 |
