Old 05-19-2011, 05:52   #1 (permalink)
riyaz_deva's Avatar
Member: 565996
Thanks Meter: 13
5130 big problampls hllp meeee
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 352678?????
Product Code: 0571981
Battery voltage: 3430 mV
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 352678???
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
phone reste opritng in white dspliy restet
Old 05-19-2011, 05:58   #2 (permalink)
Member: 732119
Thanks Meter: 64
Just flash with latest version bro ist
post then result here
Old 05-19-2011, 06:01   #3 (permalink)
riyaz_deva's Avatar
Member: 565996
Thanks Meter: 13
Version: V 07.97 not slove
Old 05-19-2011, 06:05   #4 (permalink)
Member: 732119
Thanks Meter: 64
If u have flashed ur phone wid 7.97 ver
then try usb flashing wid mx key
and don`t forget to remove camera module first
post result
Old 05-19-2011, 06:08   #5 (permalink)
riyaz_deva's Avatar
Member: 565996
Thanks Meter: 13
ok sir remov the camera and mmc ic bt ic all tested but not salove anoter usb flash in mxkey same
Old 05-19-2011, 06:13   #6 (permalink)
Member: 732119
Thanks Meter: 64
Ok dear
now it is complicated and in every forum
u will see no such type of solution that will 100% help u
discussions for such type of fault in 5130c 2690 2700c etc are in process
but nobody found perfect solution
but i tell u personally one thing that i have solved many times this fault in nokia handsets...........
Be frank to u
explain the initial condition and final condition of the handset?
Post replay so that i can help u when i understand fully the condition of the handset.............. Hope u understand
Old 05-19-2011, 11:26   #7 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
@riyaz_deva ,
try to full flash d unit first then check , mean to say first backup all important certificates then erase flash after that flash d unit with latest version & restore all certificates . do sx4 & write pm 1-309 then check.
p.s- remember first backup important cetificates (npc data, simlock data.......)
please let me know d result.
Old 06-01-2011, 09:38   #8 (permalink)
riyaz_deva's Avatar
Member: 565996
Thanks Meter: 13
hi sar not salove tnxx for the reply
how to unlock 5130 accelr8 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-24-2010 17:52
NOKIA 5130 Soft 5.71??? Erik Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 12-19-2000 17:29
5130 V.61 bzegarac Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-20-2000 11:37
5130 5190 6190 MGG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 04-03-2000 20:36
Really big favour! MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-18-1999 03:21
Page generated in 0.15080 seconds with 9 queries
