09-12-2011, 12:27 | #1 (permalink) |
Freak Poster Join Date: Apr 2007 Location: rewa (mp) india
Member: 495453 Status: Offline Thanks Meter: 22 | 5130 nokia-Flash Chip is NOT Detected ATF Box FBUS Flash Started... Number of Image Files: 3 Forcing Test Mode via BUSCHECK... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 11100019 ID DWORD 1 : DE364E50 ID DWORD 2 : BC70F2D7 ID DWORD 3 : 64E603BC ID DWORD 4 : 0A614F24 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum DD SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 01 SubBlocks : 01 1 Sub Block ID : 32 UNKNOWN Block Length : 06 BB ASIC Index : CMT 00 Device Type : HDD 02 Device Index : FF Data : FFFFFF Checksum : C8 SearchForBootstrap_DCT5 : No Error - 0 (0x00) ERROR: Flash Chip is NOT Detected ============================================ Please Check Phone PCB for Problems... ============================================ ERROR : PHONE READ INFO FAILED Use "BUSCHECK" Button to Force the Phone into Local Mode... Then "SCANPHONE" after. For N95, N95-8GB and E90 Phones, you need a Test Mode Adapter to provide some Extra Power so that the Phone will go into Local Mode... ERROR : FAILED TO BACKUP, TRY AGAIN... Changing MODE : FLASH VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 11100019 ID DWORD 1 : DE364E50 ID DWORD 2 : BC70F2D7 ID DWORD 3 : 64E603BC ID DWORD 4 : 0A614F24 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum DD SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 01 SubBlocks : 01 1 Sub Block ID : 32 UNKNOWN Block Length : 06 BB ASIC Index : CMT 00 Device Type : HDD 02 Device Index : FF Data : FFFFFF Checksum : C8 SearchForBootstrap_DCT5 : No Error - 0 (0x00) ERROR: Flash Chip is NOT Detected ============================================ Please Check Phone PCB for Problems... ============================================ Failed to complete RPL backup.. Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.97.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1178 Entry Point: 0x5057 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 11100019 ID DWORD 1 : DE364E50 ID DWORD 2 : BC70F2D7 ID DWORD 3 : 64E603BC ID DWORD 4 : 0A614F24 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum DD SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 01 SubBlocks : 01 1 Sub Block ID : 32 UNKNOWN Block Length : 06 BB ASIC Index : CMT 00 Device Type : HDD 02 Device Index : FF Data : FFFFFF Checksum : C8 SearchForBootstrap_DCT5 : No Error - 0 (0x00) ERROR: Flash Chip is NOT Detected ============================================ Please Check Phone PCB for Problems... ============================================ Operations Failed.... this is ataf data im sending ufs data 1ST BOOT : C0,07 [Rm-495] [2.2.0.2] CMT ASICID: 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 CMT PUBID : 11100019DE364E50BC70F2D764E603BC0A614F24 CMT MODE : 00 CMT HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROMID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT UNKID : 32 02FFFFFFFFC800 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 00000000: 02 00 00 00 00 D1 72 ......r ERR: CMT ALG Boot CERT MISM IMAGE : rm495__07.97.mcusw Process Failed, Repowering Mobile plz any help me |
01-15-2012, 08:28 | #3 (permalink) | |
Member: 495453 Status: Offline Thanks Meter: 22 | 5130 nokia Quote:
03-20-2014, 08:13 | #9 (permalink) |
No Life Poster Join Date: Aug 2006 Location: B A N G L A D E S H
Member: 324750 Status: Offline Sonork: 100.1590437 Thanks Meter: 302 | Dear All, This problem solved by Change CPU dual part. then automatically change IMEI but set work fine. it's Tested by me, many more phone. Flash Chip is NOT Detected first try to hit cpu if problem is still then try this way. but carefully. u have must be 100% experience on Hardware work. Best of Luck. Hossne Mamun |
