04-30-2010, 21:27 | #20 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Guangzhou-China
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 681 | Quote:
are you asked yourself why? when we remove screws this problem solve. are you asked yourself why? Nokia team not removed these screws are you asked yourself why? Why this idea did not record the IP Last edited by MOURAD™; 04-30-2010 at 21:35. | |
06-08-2010, 19:48 | #23 (permalink) |
Freak Poster Join Date: Dec 2008 Location: dubai
Member: 915625 Status: Offline Thanks Meter: 47 | change the earpiece (may be earpiece is ground) if it's not ok change the silver plate no need to loose the screw |
The Following 2 Users Say Thank You to RAHMAN007 For This Useful Post: |
02-22-2011, 11:54 | #28 (permalink) |
Insane Poster Join Date: Apr 2004 Location: poland
Member: 63175 Status: Offline Thanks Meter: 3 | is it profesionall solution? this is solution: M-495_5130Repair_Instruction_Switchesoffduringcall.d oc |
5530 power off if you call final solution | tantan167 | Nokia Base Band 5 ( BB-5 ) | 32 | 06-24-2012 13:15 |
Default BB5 power off after 20min,10min... FINAL SOLUTION | Jilani001 | Nokia Base Band 5 ( BB-5 ) | 8 | 01-20-2010 11:16 |
5530 power off if you call. solved | tantan167 | Nokia Base Band 5 ( BB-5 ) | 4 | 01-07-2010 18:36 |
5130 auto off if you call solution | tantan167 | Nokia Base Band 5 ( BB-5 ) | 2 | 01-04-2010 11:59 |
Sl55 power off if you close it | damuro | Siemens Hardware Repair Area | 9 | 11-22-2004 22:23 |
