Old 07-30-2011, 08:45   #1 (permalink)
Crazy Poster
Member: 1362693
Sonork: 433105
Thanks Meter: 2
Unhappy 5130c ERR: CMT ALG Boot CERT MISM
1ST BOOT : C0,07 [Rm-495] [2.1.0.1]
RAPx ID : 000000010000022600010006030C192101033000
EM 1 ID : 00000296
EM 2 ID : 00000B22
RAPx PBID : 1D20020D3FBF495072D2BF662156FF7EA3704BAD
RAPx MODE : 00
RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
RAPx ROID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT UNKID : 32 0110020004AF00
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
00000000: 02 00 00 00 00 D1 72 ......r
Rebooting Mobile
allready reball rap ic,but the problem r still same.any solution??
help me..
Old 07-30-2011, 12:01   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
"allready reball rap ic,but the problem r still same"
u mean already reball combo ic ( both rap& flash) . but first change fbus cable make sure it's 100% working .
if still same u need to reball againg combo flash ic (upper one) . again if still same then flash ic became faulty.
post result
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 07-30-2011, 13:31   #3 (permalink)
gsmshankarb's Avatar
Member: 1326709
Thanks Meter: 39
rehot cpu ic 10000000% solution
Old 08-02-2011, 05:33   #4 (permalink)
Crazy Poster
Member: 1362693
Sonork: 433105
Thanks Meter: 2
wich one is cpu?picture please
Old 08-02-2011, 13:47   #5 (permalink)
Crazy Poster
Member: 1362693
Sonork: 433105
Thanks Meter: 2
post result
after reball flash ic,the problem still same.then i change new one flash ic,that the result
EM 1 ID : 00000296
EM 2 ID : 00000B22
RAPx MODE : 00
CMT 1ST Boot OK
CMT UNKID : 32 02FFFFFFFFC800
CMT 2ND Boot OK
IMAGE : rm495__07.97.mcusw
Process Failed, Repowering Mobile
ANY IDEA?
Old 08-03-2011, 11:23   #6 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
Originally Posted by ejunds din View Post
CMT 1ST Boot OK
CMT 2ND Boot OK
here is ur problem , u can't fix combo flash ic properly.just try again.
btw , if u change only combo flash ic then u need to purchase nokia rpl also . but if u change both combo rap & flash then no need to write rpl . (because imei will match with public id of rap)
post result
Old 08-05-2011, 08:44   #7 (permalink)
Crazy Poster
Member: 1362693
Sonork: 433105
Thanks Meter: 2
post result
tanks sir.after reball new flash ic n flash again the problem already done.
now camera just stanby mode n charger not supported.
the log write SL DATA CORRUPTED.
what can i do to solved the problem.hardware or software?
Old 08-05-2011, 11:44   #8 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
"sl data corrupt" , yes this would be happen after change new flash ic. now u need to write nokia rpl to repair coeeupted sl data .
this is not free solution , u need to purchase rpl.
for camera problem check or write correct camera dcc file , & for charger not supported problem write good pm .
but I think will be better if u replace both combo ic from another set , because in this case u don't need to purchase rpl . (if u able to backup all important certificates including simlock data)
post result.
Old 08-05-2011, 12:55   #9 (permalink)
Member: 1326709
Thanks Meter: 39
change Avilma ic 10000000000% testead ok solution
Old 08-05-2011, 13:45   #10 (permalink)
Member: 975961
Sonork: +91-9897902397
Thanks Meter: 69
EM 1 ID : 00000296
EM 2 ID : 00000B22
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
Rebooting Mobile
help me..
u hit and change retu or betty ic
Old 08-06-2011, 15:54   #11 (permalink)
bablu333's Avatar
Member: 1495471
Sonork: 1603910:abubablu
Thanks Meter: 1,582
EM 1 ID : 00000296
EM 2 ID : 00000B22
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
Rebooting Mobile
help me..
  • bro just try to write dcc file for atf box
  • i have tested many mobile 99%
Old 08-06-2011, 19:01   #12 (permalink)
..::SADHAN::..'s Avatar
Member: 1430165
Sonork: 100.1594449
Thanks Meter: 480
try many time mx-key mark skip errase & full flash
Old 08-06-2011, 20:04   #13 (permalink)
Member: 571985
Thanks Meter: 42
rehot cpu ic............
Old 08-16-2011, 09:12   #14 (permalink)
Crazy Poster
Member: 1362693
Sonork: 433105
Thanks Meter: 2
post result.
thank for solution.rpl problem.must change flash n power ic.
boot count problem Devils-thoughts Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-06-2001 12:49
8810 & 8210 Phone NOT respond! (Load Boot data) AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-25-2001 14:47
F_loaders.bin and Boot.bin .. . micklong Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-29-2001 14:49
Phone not respond! (Load boot data) Need a help ! SashaM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-23-2001 02:10
Phone dont respond ( boot count ) galles Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-31-2000 01:53
Page generated in 0.29109 seconds with 9 queries
