Old 03-14-2006, 17:42   #1 (permalink)
PSG
PSG's Avatar
Member: 27761
Thanks Meter: 43
5140 no network , not charge
hi
i have nokia 5140 no network and no charge.
i replace fuse and now nokia is charging OK but still i have to fix network problem.
if i make manual network search option then after 1min and 15sek nokia display 3 networks + home network but can't logon into home network
imei is OK i mean phone is not barried 100% (i change imei for test and still no network)
i think uem is ok and RX ok but if phone can't login to net TX must be bad.
i try PM + reflashing but no network still.
Old 03-14-2006, 18:02   #2 (permalink)
PSG
PSG's Avatar
Member: 27761
Thanks Meter: 43
is it HAGAR ? if yes please post picture coz all chips in 5140 are only with numbers not names
Old 03-14-2006, 18:18   #3 (permalink)
enzawigroup's Avatar
Member: 141363
Sonork: 100.1594362
Thanks Meter: 147
hi all writ full pm and the problem is fin
Old 03-15-2006, 10:58   #4 (permalink)
PSG
PSG's Avatar
Member: 27761
Thanks Meter: 43
i made it before. read post and then make answers.
Old 03-15-2006, 13:48   #5 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
which you can do some cheap application to help against the future.
1.try checking using phone code
2 check charger interfacew before any thing(PCB).
3. module(IC's) before any application
4. external socket to phone.
5. battery to your phone.
6.capacitors to panel on board.
7. wrong charger can cause this problem.
8. sim chamber can become a problem to this .
try this later , from bestman
bestman
Old 08-27-2006, 00:55   #6 (permalink)
Member: 301949
I've the same problem
I've the same problem. My nokia don't found network and don't charge.
Please, can we send me the instruction for the solution and the manual.
THZ
Old 02-20-2008, 10:43   #7 (permalink)
Member: 708963
I have a problem in the network For nokia 5140i want solution please
Old 05-29-2008, 21:59   #8 (permalink)
Member: 758550
Thanks Meter: 15
Same problem have been solved today by replacing PowerAmplifer N700 and now it's OK.
5140 no network CjsCellular Nokia Hardware & Hardware Repair 0 04-27-2007 16:01
Nokia 5140 No Network sleurhut Nokia Digital Core Technology 4 ( DCT-4 ) 4 12-02-2006 13:15
Nokia 5140 no network and charge? jhoncybpr Nokia Hardware & Hardware Repair 0 08-28-2006 20:17
5140 NO Network - need help. PSG Nokia Hardware & Hardware Repair 4 04-20-2006 18:40
3310 no network &stop charging goldeneagle Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-09-2005 07:41
Page generated in 0.28413 seconds with 8 queries
