03-01-2007, 03:06 | #1 (permalink) |
Major Poster Join Date: Feb 2007 Location: CAPIZ
Member: 456286 Status: Offline Thanks Meter: 5 | N73 NOt charging.. |
The Following 2 Users Say Thank You to jake007 For This Useful Post: |
01-20-2008, 01:33 | #9 (permalink) |
Crazy Poster Join Date: Jun 2005 Age: 39
Member: 155571 Status: Offline Thanks Meter: 2 | N73 and E65 not charging Hi! There isn't Retu in the N73! So you can't change it... Check the charging pins. If shorted cut the positive, remove the fuse and make a jumper. Check Btemp resistor and Btemp value. Check charging electronic. Maybe 4 or 5 components. If problem still exists change Betty, and last Avilma! I had an E65 with charging problem! I changed the betty - nothing. So with me the Avilma can helped! Of course, the charging problem maybe software or calibration problem, so before you try hardware repair please flash the phone. If I make a mistake in this steps, please correct me! Bye, and good luck! |
01-22-2008, 04:58 | #10 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Beside U Age: 37
Member: 647414 Status: Offline Thanks Meter: 127 | hello all frenz try change betty is oso cannot charging try change power ic 1000% work for u all....... WinD |
The Following User Says Thank You to WinD_VteC For This Useful Post: |
i need Solution n73 not charging | GSMJordan | Nokia Base Band 5 ( BB-5 ) | 3 | 09-25-2009 14:46 |
n73 not charging | ibraheem0079 | Nokia Hardware & Hardware Repair | 5 | 08-03-2009 10:02 |
N73 Not Charging Need Help | Nasmi | Nokia Hardware & Hardware Repair | 0 | 06-05-2008 13:25 |
n93 and n73 not charging....? | helin | Nokia Base Band 5 ( BB-5 ) | 6 | 10-16-2007 17:26 |
Help N73 not charging | mahdiqaladza | Nokia Hardware & Hardware Repair | 3 | 10-12-2007 16:37 |
