Old 12-07-2008, 09:45   #1 (permalink)
Member: 150086
Thanks Meter: 20
5200 flash ok ,but no power on ??
hi ,
i flashing 5200 ,flash ok ,but not power on ??
any solution ??
Old 12-08-2008, 03:49   #2 (permalink)
Rizal Arsyad Dini's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 6,137
try to use higher version...
regards
Old 12-08-2008, 03:55   #3 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
Originally Posted by bigbos View Post
hi ,
any solution ??
BEFORE HARDWARE"
flash again the phone with different version using hwk or
jaf be sure 7pins cable after flash write pm
Old 12-08-2008, 05:32   #4 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 571
HI:
after flash chack on/off ways...........
Old 12-08-2008, 05:55   #5 (permalink)
Member: 774169
Thanks Meter: 123
check wheterh its charging or not ???
Old 12-08-2008, 06:15   #6 (permalink)
ANH BO's Avatar
Member: 734429
Thanks Meter: 34
please log post. i'am can u help
Old 12-08-2008, 06:23   #7 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
show the logs sir
br
The Following User Says Thank You to raezak For This Useful Post:
Old 12-08-2008, 15:07   #8 (permalink)
Member: 350629
Thanks Meter: 18
Old 12-08-2008, 15:16   #9 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
first u show ur logs here if u want better help
Old 12-08-2008, 16:43   #10 (permalink)
Member: 654510
Thanks Meter: 21
check charging is ok or not ........
Old 12-08-2008, 18:58   #11 (permalink)
Member: 398194
Look at to the flexible cable, try to changed first
Old 12-08-2008, 19:38   #12 (permalink)
Teepat's Avatar
Member: 599669
Thanks Meter: 115
bro explain your phones problem in details.after flash was your phone charging?if yes than you know that your swicht is bad.than if know flash with a higher version.all the best.
Old 12-08-2008, 20:06   #13 (permalink)
multi_mobile's Avatar
Member: 502659
Thanks Meter: 101
5200 problem
my dear frist you write latest firmware when write done then give info
if show info and no power thenchange the flex ur problem slove
Old 12-08-2008, 20:48   #14 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
first u should post the full flashing log
any way if flahing with higher version not help then jus try with this ...
just use some paste on rap and flasher and rehot or put it under 100w light for 15 minutes and u will smile ...
S45 flashing OK, but no power on doggyfreestart Siemens Hardware Repair Area 3 11-27-2005 18:43
e700 flash ok but no power on MTi-GsM SYSOL Platform 5 07-01-2005 19:58
6820 flashing ok but no power on Cat10 Nokia Hardware & Hardware Repair 3 03-22-2005 19:49
7210 Flashing Ok but no power on! Ercie Nokia Hardware & Hardware Repair 6 02-18-2005 01:01
8210 charge OK, Flash OK, but no power on Two-Dogs Nokia Hardware & Hardware Repair 1 01-20-2003 07:46
Page generated in 0.23803 seconds with 9 queries
