5210 Continue to charge after unplug Hi mates, I have this one 5210 which suddenly starts to shows/continue to charge even after i unpluged the charger!! what might be the cure? WBR, BANTUGBRO. |
b.r. akki |
change charging ic cotrol , change ccont , check lines around ic charging cotrol.... |
no no not need to change ccont 100% sure. this fault is same like 3310 reconact charger. thats all. b.r. akki :cool: |
nooo you are always in need to change ccont when you have a short circuit .... |
no need to change ccont. I agree with Akshay.It Is same with 3310.You have cut line in pcb and charging IC cannot control the function.I will try to make a picture to help you as soon as posible. WBR. |
sometimes you will face some charging problems which will never solve unless you change ccont man. to insure refer to the forum , good luck.... |
@SRNOURI ..Pls provide us with the picture! WBR, BANTUGBRO. Quote:
Check V batt on C105 must be 3.8V That's all. BR |
just jumper the line c165 to c105 |
THANKS t-6... perfect soultion! Works 100% tonytony |
Hi where can I download 5210 MCU and PPM with Persian or english language ? Its flash files are not listed in UFS support area. can anyone gimme a link to download them or send them to [email protected] ? hope to hear soon have fun moly |
