06-19-2003, 06:54 | #1 (permalink) |
Junior Member Join Date: Jul 2001
Member: 5149 Status: Offline Thanks Meter: 0 | 5210 force downgrade to 8250 i got a 5210 with a defective hardware flashrom (Phone Ram Bad),i reball it and it still Phone Ram Bad. Unfortunately, i ran out of 5210 flashrom and was forced to use 8210/8250 flashrom as substitute. After replace and flashing it w/ 8250 flashfile, it works (incoming/outgoing calls/sms works fine) except that display is reversed (and all other 5210 features are lost) is there a hardware solution/software solution for this reversed display? i wish i could use 8210/8250 flashrom because it is more durable compared to 5210 h.w. flashrom, which easily gets damaged/defective (Through repair experience in 5210). |
06-29-2003, 01:32 | #4 (permalink) |
Member: 5149 Status: Offline Thanks Meter: 0 | @edoy it works but 2100 is much higher resolution and display aint reversed,you can see 2100 display partially. gonna try 2100 lcd hope this works i've encountered reversed lcd in 7110, although this one is an accident, display was flipped same w/ the post i mentioned. maybe it has something to do w/ the hardware coz the lcd 'contact' aint 'properly' connected, still working at it how to 'reverse' it again coz only happened once thnx for reply, bga |
Any possibility to force downgrade firmware | commandoo | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 03-28-2010 09:18 |
How much time To Fix DCT4 Bug With Ufs! Why u Force us To Buy Patatoooo Box | memobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-20-2010 11:28 |
Is it possible to force phone to boot in local/test mode? | yurais | Nokia Base Band 5 ( BB-5 ) | 24 | 06-20-2008 00:26 |
??? software to upgrade 3310 to 3315; 8210 to 8250 all in one | JUNT | Nokia Multimedia | 1 | 05-27-2003 06:26 |
how to convert 8210 to 8250 | tra0416 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2002 12:04 |
