06-15-2003, 05:34 | #1 (permalink) |
Major Poster Join Date: May 2001 Location: egypt
Member: 4669 Status: Offline Thanks Meter: 0 | 5210 hang then power off |
06-16-2003, 13:01 | #6 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | @ mamdouh Did u try to reflash the phone? I had same problem. Reball MAD2. Should work in most cases. @willy Will if 82X0 or 52X0 wont communicate with PC .. example jsut erases flash and wont write back is it a MAD2 problem too? :/ How to remove completely the sort of glue from under the MAD2?? i thought it was just surreoundign the chip not even aroudn the balls. It makes the job really hard that stuff Normally freezing , frozen LCD etc are all MAD2 related especilly in 82X0. thanks al |
06-16-2003, 20:32 | #7 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Burnt Cobba, what i can say ? it most time, flash rom or MAD problem ! those under fill glued chips, for me, only use hot air and knife with full careful ,, that it ! at 8250, that bad history, it rusty in K1 L1 M1 N1 those pin ! 8210 hung between MAD to hager ! willy |
6555 hang then switch off | jamohaki | Nokia Hardware & Hardware Repair | 1 | 03-08-2011 08:14 |
6120c, white screen then blue screen then power off | DjDecibel | Nokia Hardware & Hardware Repair | 6 | 02-26-2011 10:33 |
ku250 low battery then power off even in power supply | eljhay | LG | 0 | 01-04-2010 14:25 |
nokia 6600 hang and power-off after pincode off | rovick | Nokia Multimedia | 3 | 08-04-2008 12:23 |
E700 Keypad Hang Then Switch Off | jamohaki | Samsung Hardware Repair | 2 | 11-02-2007 06:02 |
