Old 02-05-2004, 00:18   #1 (permalink)
Member: 27606
Thanks Meter: 15
5210 network problem
after it fell from 2 meters high no signal,try to replace PA and antena switch,rehot cobba,what can I do next,some advice,i tried to find network manualy but it can't after 30 sec. of phone restarts by it self,any smart idea's
Old 02-05-2004, 01:02   #2 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Thanks Meter: 74
@zvonimir
If the phone restarts by itself, or when you push any buttoms, first you have to look into the Flash IC, next step is the CPU which is the "Bad Wolf" on these models, since both Flash and CPU is unglued !!
I suggest you first lightly reflow the flash, upgrade it to latest version, set FAID ect, and see if it gets signal. Otherwise I would go after the CPU.
If you have instruments like Ocilliscope, Signal genrerator, wintesla ect i can give a more detailed instruction, but you can find the same in the Service Manuals step by step. Did you try to read RSSI with Wintesla ? Because this can give you a pretty good idea whats wrong with the phone if either TX or RX is broken.
Regards
nokia 5210 network problem !!! dapinderjit Nokia Hardware & Hardware Repair 2 02-23-2009 19:54
5210 network problems thecult Nokia Hardware & Hardware Repair 4 02-04-2004 07:22
5210 network problem Ivand Nokia Hardware & Hardware Repair 0 06-29-2003 15:08
5210 network problems trafix Nokia Hardware & Hardware Repair 0 10-19-2002 22:43
Page generated in 0.13141 seconds with 9 queries
