02-03-2004, 21:41 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | 5210 network problems if you search manually it finds all networks I have replaced antenna switch and rehoted cobba but same problem. any help? I don't have advanced tools for find network problems. I work by probabilities (I want to buy equipment, but is too soon). thanks a lot b.r. |
02-03-2004, 22:06 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Replace the Power Amplefire , befor U can dettect it by the use of a sensitive chinees light emmiting diodes (LEDs) with battery. It feels the radiated signal from the phone and (as a triguerd memory ) stays flashing lights for about 10 sec. , also the presence of the battery makes it sensitive to the signal out from the phone. |
02-04-2004, 00:46 | #3 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | for me the best to know if the phone transmiting put led flashing stick WITHOUT BATTERIES close to antenna.this one lights only when you have amplified from P.A output radiation.flashing stick with bateries can light with preamplifiing signal. |
02-04-2004, 07:22 | #5 (permalink) |
Freak Poster Join Date: Jul 2002 Location: MAD Age: 50
Member: 13545 Status: Offline Thanks Meter: 2 | Does the signal comes and go with Or without TX ...? to find out if it has TX or not put the phone near your monitor , if you see flickness when the Tx comes then try check cobba, if u did not see and flickness then change PA, and also read rssi it is helfull, Good Luck -------------- MrHazeem |
nokia 5210 network problem !!! | dapinderjit | Nokia Hardware & Hardware Repair | 2 | 02-23-2009 19:54 |
5210 network problem | Destructor | Nokia Hardware & Hardware Repair | 1 | 02-05-2004 01:02 |
5210 network problem | Ivand | Nokia Hardware & Hardware Repair | 0 | 06-29-2003 15:08 |
5210 network problems | trafix | Nokia Hardware & Hardware Repair | 0 | 10-19-2002 22:43 |
