Old 04-15-2003, 18:35   #1 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 41
5210 Sim card not Valid
Help me solve this problem man ....
first time came, phone dead, replaced Flash ok.
But now when insert sim (Working Sim) it says, "Sim card Not Valid"
Pls help me..
thx
Old 04-16-2003, 00:15   #2 (permalink)
Member: 16036
Thanks Meter: 5
hi man
just unlock it
should work
bye
Old 04-16-2003, 10:05   #3 (permalink)
Member: 14004
Thanks Meter: 6
As mohammed said, first try to unlock it. Then try to full flash it and recalculate faid with KNOK.
Then read the full flash from your phone with KNOK. Compare this file with file you used for flashing. If they are not identical - change combo flash again.
If above is OK, then check contacts, check/replace V104, R124, R125, R128, C128, C127.
Check the Vsim (3V or 5V) at C128.
Check the Vsrm at C131 RF and V5V at C108.
Check the regulator N600, V116, C132 and C131.
If everything above is OK, than change the CCONT N100.
Old 04-16-2003, 18:56   #4 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 41
wow....
its unlocked already .... but ill try to compare the flash first.
thx 4 ur reply ...
Old 04-17-2003, 09:52   #5 (permalink)
Member: 22526
Very good stuff Johny3310!!!
Old 04-17-2003, 17:38   #6 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 41
replaced new flashed ... then OK.
Thx guys
6630 SIM Card Not Valid ccw123 Nokia Base Band 5 ( BB-5 ) 6 07-11-2009 16:34
N95 8gb not unlock lost mi sim card not valid ruchito Universalbox 1 03-30-2009 20:55
SIM CARD NOT VALID using PBB ON A N6600 stevie Phoenix Black Box 8 07-25-2005 13:54
Page generated in 0.37468 seconds with 8 queries
