Old 12-04-2009, 06:41   #1 (permalink)
smsismail's Avatar
Member: 603496
Sonork: 100.1656628
Thanks Meter: 215
Question 5220 camera on standby
5220 camera on standby pl help
The Following 4 Users Say Thank You to smsismail For This Useful Post:
Old 12-04-2009, 06:45   #2 (permalink)
GsmEasy's Avatar
Member: 608359
Sonork: 100.1576815
Thanks Meter: 5,351
no need to open your phone use mx key and repair your phone in 2 sec without open
[Share here] Dynamic Camera Configuration / CAMERA ON STANDBY PATCH
The Following 6 Users Say Thank You to GsmEasy For This Useful Post:
Old 12-04-2009, 07:45   #3 (permalink)
Thinh vu's Avatar
Member: 830301
Sonork: heocon
Thanks Meter: 46
Can you tell me that he posted 4 files , so which files for which phone
The Following User Says Thank You to Thinh vu For This Useful Post:
Old 12-04-2009, 10:24   #4 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,427
this file download and write phone with mx key
http://rapidshare.com/files/31613030..._By_Camera.rar
Old 12-04-2009, 10:49   #5 (permalink)
Member: 300547
Thanks Meter: 23
i think sw problem........can try by flashing
The Following User Says Thank You to abhi_gsm For This Useful Post:
Old 12-04-2009, 10:55   #6 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,427
not sw problem i m solve 5130c and 5220 lot of times see this picture
http://rapidshare.com/files/306306565/21o1se9..jpg
Old 12-04-2009, 22:34   #7 (permalink)
chohansahib's Avatar
Member: 719944
Thanks Meter: 2,117
Hi dear,
try to change camera if problam still same then try this solution ur problam will solve..........
The Following 5 Users Say Thank You to chohansahib For This Useful Post:
Old 12-17-2009, 09:44   #8 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 91
To repair camera after contact service lets say, no need any box to fix in 4 sec, okay it's 2 sec more than mxkey, but ...
B.R.
Alkapone
Old 12-20-2009, 21:39   #9 (permalink)
Member: 344558
Thanks Meter: 5
Can you explain your idea?
Old 12-21-2009, 18:19   #10 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 91
Nothing to explain if for real, need sometimes to 'turn on' brains Just install cracked phoenix, and write camera settings (existing settings: XXXX.XXXX new settings 2007:2007 or something). Phoenix will write them automatically, no need any knowledge.
B.R.
Alkapone
The Following User Says Thank You to Alkapone For This Useful Post:
Old 12-22-2009, 05:52   #11 (permalink)
Member: 285377
Thanks Meter: 7
just ur camera stand by that u r problem camra ic reheat or change ic it ,,,,,,,
Old 12-22-2009, 06:28   #12 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 91
Seems 90% of people coming into this forum can't read or use drugs or something. I've wrote - Camera on standby after CONTACT SERVICE can be easily fixed using Phoenix. If you get 5220 with CS make unlock let's say with genie and phone OK, camera wont work! Will be on stand by.
B.R.
Alkapone
Old 01-08-2010, 18:03   #13 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,516
I've just confirmed that solution is with phoenix, and very easy, luck
Old 10-05-2010, 17:32   #14 (permalink)
Member: 1200908
Thanks Meter: 2
Plz help me...after flashing from v6.51 upgrade to 7.23...camera stand by...
MCU SW : V 07.23 17-07-09 RM-411 (c) Nokia
PPM SW : V 07.23 17-07-09 RM-411 (c) Nokia X
Product : Nokia 5220 XpressMusic
Prd.Code: 0564177
Bpr.Code: 0554881
Prod.Sn : DQG301762
HW Vers : 1000
EM VILMA: 15
EM BETTY: 22
RFIC Ver: 064c0601
DSP Vers: ICPR72_09w17
LCD Type: SHARP
CAM Prim: XXXXXX (DCC Mismatch)
IMEI : 353662-01-459579-7
SL Serv : SIMLOCK SERVER
SL Conf : 244-07-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland
Old 12-16-2011, 09:27   #15 (permalink)
Member: 1699857
Sonork: 100.1669194
Thanks Meter: 10
Camera Id xxxxxxxxx File Not Found
5220 camera on standby ok sajidashraf MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-27-2010 16:24
5220 camera on standby kong5271 Universalbox 3 02-24-2010 18:01
5220 camera on standby kong5271 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-24-2010 17:22
5220 camera on standby gsm_dreemy Nokia Hardware & Hardware Repair 0 08-11-2009 07:44
camera on standby 6280 says while operating camera gsmservices MT-BOX 0 09-06-2006 16:41
Page generated in 0.43290 seconds with 9 queries
