Old 01-04-2009, 12:31   #1 (permalink)
Member: 476772
Thanks Meter: 4
5300 on appear nokia all the time .....only
use HWK check ok, flash ok ,
but ui settings failed .....
my version high ......cable ok ..... because try other 5300 ok ....
Old 01-04-2009, 12:36   #2 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
didnt make ui if not show local mode or test mode
after flash, try flash another version or flash using jaf...
Old 01-04-2009, 12:46   #3 (permalink)
Member: 617971
Sonork: 100.1592154
Thanks Meter: 64
bro can you plz help me n1100 lcd wayzz????
Old 01-04-2009, 12:50   #4 (permalink)
Member: 476772
Thanks Meter: 4
I USE JAF ALSO SAME PROBLEM ....
appear phone aborting failed .......
Old 01-04-2009, 14:31   #5 (permalink)
rumenshom's Avatar
Member: 899774
Sonork: 100.1586303
Thanks Meter: 449
http://www.4shared.com/file/78883413...localmode.html
your problem is like localmode......
so try this.....
The Following 2 Users Say Thank You to rumenshom For This Useful Post:
Old 01-05-2009, 03:18   #6 (permalink)
Member: 476772
Thanks Meter: 4
so try this.....
there write ...\
remove this resistors ,
but
after i remove , can not check by HWK....
Old 01-06-2009, 03:43   #7 (permalink)
Member: 476772
Thanks Meter: 4
i rechange already ..... still can not solve ....
Old 07-10-2009, 14:12   #8 (permalink)
Member: 434317
Thanks Meter: 15
Hi mates,i have same problem with 5300..i also do TANGINGSIANG process. but nokia logo only coming..
what is next to do?
HELP, 6120c on appear nokia moment, then appear blue screen ..... TANGINGSIANG Nokia Hardware & Hardware Repair 9 02-25-2010 14:42
bb with battery on the lcd all the time wilmer BlackBerry (RIM) 0 03-25-2009 08:17
Box goes on an off all the time Tele-way.dk BB5BOX 2 10-13-2007 21:19
nokia 6210 charging all the time and 8210 no power on emmibox Nokia Hardware & Hardware Repair 0 08-30-2001 05:46
3310 dropped in water ,still works but the display leds are on all the time wildwhacker Nokia Hardware & Hardware Repair 1 08-13-2001 03:50
Page generated in 0.21656 seconds with 9 queries
