Old 07-28-2010, 14:55   #1 (permalink)
gsm_doc's Avatar
Member: 967780
Sonork: 100.1587141
Thanks Meter: 75
Arrow 5310 on after that goes to blue and restarts
5310 on after that goes to blue and restarts.
I have nokia 5310 music express the condition of phone when came to me was , when we on phone it shows nokia logo after that goes to blue then restarts ............
I flashed the phone with version 7.1 & version 9.42 then with 10.10 but phone flashes perfectly but after flash it doent goes to test mode or local mode as usually other mobiles do after flashing.
The NPC data of phone is fine .
I flashed through
UFS, MX key , MT
now what to do can any one help thanxxx in advance
The Following User Says Thank You to gsm_doc For This Useful Post:
Old 07-28-2010, 19:57   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,340
yesterday I repair a 5310 with same fault , just reflow or reball avilma then check
post result
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 07-28-2010, 21:18   #3 (permalink)
Member: 39208
Thanks Meter: 150
could be also sw problem, try sw update!
Thank You
Byte
Cheap Hosting
Web Hosting Services, Reseller Hosting, and Dedicated Servers by HostGator
The Following User Says Thank You to Byte For This Useful Post:
Old 07-28-2010, 21:22   #4 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,283
I flashed through
UFS, MX key , MT
juz try to remove mmc ic then try
The Following User Says Thank You to WAJID PNR For This Useful Post:
Old 07-28-2010, 21:47   #5 (permalink)
geosan1638's Avatar
Member: 5204
Thanks Meter: 35
easy.....just remove audio codec, clean and inspect for water damage. This IC is i2c controlled so ...you get the picture. good luck
The Following User Says Thank You to geosan1638 For This Useful Post:
Old 07-28-2010, 23:14   #6 (permalink)
Member: 1338457
Thanks Meter: 31
backup rpl using jaf . then make erase full with erase file and flash new ver 10.10 check now ur phone may be working but imei coming 1234..................... like ,, ok now u re write backp rpl set goes the previous condition same blnging it means ur rpl is not good make rpl servic
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 19:29
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.29789 seconds with 8 queries
