10-20-2008, 21:49 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::5310 camera on standby::.. i found only one solution on forum but it not worked |
The Following 10 Users Say Thank You to HUM For This Useful Post: |
10-21-2008, 07:41 | #2 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Palestine Age: 40
Member: 26041 Status: Offline Thanks Meter: 160 | hi friend I also tried the same solution but not worked , i had 5 phones neeed solution , hope any one have solution . Best Regards. |
The Following 4 Users Say Thank You to .:RoMeO:. For This Useful Post: |
10-22-2008, 19:19 | #4 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | anyone have tested solution i try to changecamera also but still same |
The Following 3 Users Say Thank You to HUM For This Useful Post: |
10-22-2008, 19:35 | #5 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Hwk is the BEST NOKIA TOOL
Member: 735523 Status: Offline Sonork: 100.1591830 Thanks Meter: 262 | hi pro try 2 change the camera and check the raps d3000 see the schematics i test these solution in 2 phone same problem camera on standby |
The Following 3 Users Say Thank You to azez.sd For This Useful Post: |
01-22-2009, 12:12 | #11 (permalink) |
Insane Poster Join Date: Jan 2005 Location: South Africa Age: 50
Member: 110065 Status: Offline Thanks Meter: 25 | Got camera to work again. Remove the cover over the camera. remove battery. press down on the camera, while pressing down the camera insert battery and turn on the phone and test the camera. if it works your camera holder is not keeping the camera in place. |
The Following 20 Users Say Thank You to Mikie274 For This Useful Post: |
.::100% solution of 5130 & 5310 camera on standby::. | amar181 | Nokia Base Band 5 ( BB-5 ) | 281 | 11-11-2015 14:41 |
.::100% solution of 5130 & 5310 camera on standby::. | king.of.gsm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 22 | 09-20-2012 14:39 |
..::5130c ringer,loudspeaker & camera on standby::.. | HUM | Nokia Hardware & Hardware Repair | 7 | 09-15-2011 16:44 |
.::100% solution of 5130 & 5310 camera on standby::. | rubel_chk007 | Nokia Hardware & Hardware Repair | 15 | 02-20-2010 12:11 |
