03-11-2010, 05:39 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: pakistan
Member: 334999 Status: Offline Thanks Meter: 225 | 5310 full short? i parchaz the new set but drop the set and after i check the set so my set full short. set wash but same problem sir plz any slution post me if u have any picture so send me .plz:confu sed: BIG THANKS |
The Following User Says Thank You to asif_ae For This Useful Post: |
03-11-2010, 05:51 | #2 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 533912 Status: Offline Thanks Meter: 115 | 2shared - download untitled.bmp check shorting in 5310.. 1..remove this coil mark in (1)...if u want to check is light ic is short,..... 2..remove this coil mark in (2)..if u want to check ringer ic is short because rf ic also got +b volt from battery.... 3..remove this coil mark in (3)..if u want to check audio amplifier voltage maker ic n2101 is short because bluetooth ic also got +b volt from battery.... 4..remove this rf ic mark in (4)..if u want to check the shorting is remove because rf ic got +b from batery. it can be check only by removing this ic 5..remove this ic mark in (5)..if u want to check the shorting is removed..this ic also got +b it can be check only by removing this ic . 6..also check the blue tooth ic because it also got +b from batery it can be check only by removing this ic 7..at end remove avilma and betty ic... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... |
The Following User Says Thank You to mohammed imran For This Useful Post: |
W 700 i full short | surajnad | Sony Ericsson Hardware Repair | 0 | 08-14-2007 15:59 |
N70 full Short | cellengineers | Nokia Hardware & Hardware Repair | 3 | 07-07-2007 08:09 |
Nokia 6600 full short | zakir375 | Nokia Hardware & Hardware Repair | 3 | 04-23-2007 13:38 |
K310i Full Short | ..::Mr_Fone::.. | Sony Ericsson Hardware Repair | 5 | 03-15-2007 21:29 |
6100 full short | abbasok | Nokia Hardware & Hardware Repair | 14 | 03-05-2007 17:01 |
