5510 No Audio Hello, i have one unit here with no audio - no speaker and no MP3! Any idea where could i start? earphone is ok and connector for headset too, reballing cobba ic havent helped! :rolleyes: Thanx Platy |
Change 11.xxxMhz crystal on UI module! If not work, flash it UI module. |
Hi. How to flash UI module? Becuase I have broken UI module 5510. Thanks for attention. |
i think u must check arrowned cobba after that check cobba |
Hello, i have this phone back. Still same problem - NO AUDIO from speaker and MP3 too... interesting is that when i switch on phone KEY TONES work until startup LOGO! but after startup logo phone is totaly silent in MP3, RADIO and SPEAKER, only buzzer works.... so i think it is not broken link problem, i already tried change cobba, flash it, MCU+PPM+EPP + total reset + Flash UI DSP .... no result :confused: anyone can help me?? Thanx a lot Platy |
Cobba Hi platy have you tried to reflow/replace the Cobba? if not then I suggest you try Later D. :D |
i already tryed change cobba ... :mad: :mad: :mad: |
Try to reflash DSP board. WBR b0ba |
@platy You can grab the UI DSP flash tool from my web here This zip pakckage containds all files nessesary. Tested many times by me and others. Regards |
Problem is already in External DSP board - i tested phone with another and it works good. But i still dont know where is problem on that DSP - i already flashed it with Ext DSP tool and it doesnt helped :confused: Platy |
BR, s1emens |
already have it from another forum. thanks anyway br, s1emens |
:D :D Hehe (c) Crew. Regards Thread closed |
