5510 work only 10 seconds after power on I have one 5510 without any hardware faults not water damage When I power on it without simcard it works 10 seconds display Insert SIM and then power off Same with simcard WHAT'S THIS ????????????????? |
Search the forum, there are old post concerning this problem. I think that some people fixed this problem flashing EXT UI board with newer version. The link for flashing soft is also in old posts. Regards, Nylus. |
I think that it is a problem like 7650 with full memory because i flash new eeprom and full flash package 3.53 ??????????????? |
@Mishka, Its not a problem in MCU+PPM+EEPROM... Its a problem in MP3 DSP section.. U need to flash your DSP read old post for more details.. Best Regards, Wahab |
Use EXT_UI board 2.0 Try this if you have a working FBUS cable. I hope it can help as 100% tested by me. Cable modification: Cable rx -> phone tx Cable tx -> phone rx Cable GND -> phone GND And Run ext_ui board 2.0 After Step 1 (selecting ini & data file) Phone must be Off. - Now Connect Charger (Fast charger is advisable) - Don't Power On the Phone (phone will boot and only battery bar indicator will appear) - Then proceed clicking the Step 2 Button (11 min and 30secs approximately) - Step 3 B.R. |
