Old 05-15-2003, 18:19   #1 (permalink)
Crazy Poster
Member: 24334
5510 work only 10 seconds after power on
I have one 5510 without any hardware faults not water damage
When I power on it without simcard it works 10 seconds display Insert SIM and then power off
Same with simcard
WHAT'S THIS ?????????????????
Old 05-15-2003, 19:38   #2 (permalink)
Member: 10087
Thanks Meter: 2
Search the forum, there are old post concerning this problem. I think that some people fixed this problem flashing EXT UI board with newer version. The link for flashing soft is also in old posts.
Regards,
Nylus.
Old 05-15-2003, 20:18   #3 (permalink)
Crazy Poster
Member: 24334
I think that it is a problem like 7650 with full memory
because
i flash new eeprom and full flash package 3.53
Old 05-15-2003, 20:37   #4 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,694
@Mishka,
Its not a problem in MCU+PPM+EEPROM...
Its a problem in MP3 DSP section..
U need to flash your DSP
read old post for more details..
Best Regards,
Wahab
Old 05-16-2003, 22:45   #5 (permalink)
Springer's Avatar
Member: 15909
Use EXT_UI board 2.0
Try this if you have a working FBUS cable. I hope it can help as 100% tested by me.
Cable modification:
Cable rx -> phone tx
Cable tx -> phone rx
Cable GND -> phone GND
And Run ext_ui board 2.0
After Step 1 (selecting ini & data file)
Phone must be Off.
- Now Connect Charger (Fast charger is advisable)
- Don't Power On the Phone (phone will boot and only battery bar indicator will appear)
- Then proceed clicking the Step 2 Button (11 min and 30secs approximately)
- Step 3
B.R.
nokia e90 gets hot 10 minutes after powering on and hang.inner screen dark GOODNESS Nokia Hardware & Hardware Repair 4 02-23-2011 13:18
Any help samsung i900 only omnia logo after power on Mounir Samsung Flashers, Software, Firmware. 0 05-12-2009 12:30
V3 Only No button not work after Power on nasirahmed Motorola Hardware Repair 2 02-12-2008 08:54
6016i shuts off 10 seconds after power up felix23 Nokia Hardware & Hardware Repair 0 06-20-2006 20:14
A800 displays only square line after power on!! GSM SNIPER Samsung Hardware Repair 12 07-17-2004 22:34
Page generated in 0.14427 seconds with 9 queries
