Old 09-12-2013, 12:42   #1 (permalink)
Registered User
Member: 1077541
Thanks Meter: 77
5530 vibrate only
5530 vibrate only.flash ok but ui setting error,bsi line good,how to solve this problem
The Following User Says Thank You to saman kumara For This Useful Post:
Old 09-12-2013, 15:00   #2 (permalink)
Member: 1736861
Thanks Meter: 18
Bro change avilma power ic i m tested
The Following User Says Thank You to ...MOBILE-HOSPITAL... For This Useful Post:
Old 09-12-2013, 15:42   #3 (permalink)
Registered User
Member: 1077541
Thanks Meter: 77
not solved..........................
Old 09-12-2013, 16:07   #4 (permalink)
N.C.Erepola's Avatar
Member: 1615710
Sonork: 100.1647890
Thanks Meter: 260
Flash again with different version and use following settings for UI
use all other settings with out Software upgr. default and Reboot in normal mode.
Old 09-12-2013, 16:13   #5 (permalink)
Registered User
Member: 1077541
Thanks Meter: 77
flash available highest version hwk & best & phoenix but not solve
Old 09-12-2013, 19:22   #6 (permalink)
Registered User
Member: 1077541
Thanks Meter: 77
any body have other solution
Old 09-12-2013, 20:25   #7 (permalink)
ashishsingh's Avatar
Member: 1424659
Sonork: 100.1648352
Thanks Meter: 142
Check display if ur set water damage remove camera not solve rehot rep ic remove gun nosel
Old 09-13-2013, 18:10   #8 (permalink)
Member: 1501291
Sonork: 100.1622368
Thanks Meter: 24
use latest version
and then post result
Old 09-13-2013, 18:12   #9 (permalink)
Registered User
Member: 1077541
Thanks Meter: 77
Originally Posted by mkashifbilal1 View Post
use latest version
already use latest file.have any solution
Old 09-29-2013, 09:02   #10 (permalink)
Registered User
Member: 1077541
Thanks Meter: 77
finally i'm find the solution
Old 10-01-2013, 16:58   #11 (permalink)
Member: 302110
Thanks Meter: 6
and what is the solution???
Old 10-05-2013, 07:56   #12 (permalink)
Registered User
Member: 1077541
Thanks Meter: 77
which you have flash tool ,contact me [email protected]
Old 10-06-2013, 20:48   #13 (permalink)
Member: 890979
Sonork: apondave
Thanks Meter: 2
i have nokia n 70 its so white screen plese help me
Page generated in 0.17970 seconds with 9 queries
