12-13-2007, 09:43 | #1 (permalink) |
Insane Poster Join Date: Mar 2006 Location: Philippines/U.A.E
Member: 247685 Status: Offline Thanks Meter: 44 | 6300 LCD blinking then off Thanks |
01-29-2008, 22:55 | #2 (permalink) |
Junior Member Join Date: Sep 2005 Location: NZ Age: 51
Member: 184249 Status: Offline Thanks Meter: 0 | i have got the same problem, lcd blinks 2-3 times then whole phone powers off, i have reloaded software - sucessfully, however fault presisted. Any solution's ? |
06-20-2008, 15:41 | #6 (permalink) | |
Junior Member Join Date: Aug 2006
Member: 339548 Status: Offline Thanks Meter: 0 | misunderstood Quote: i agree it may be rap3.mine gots it but not even wants to flash.bootin phone but then error sync the phone. | |
06-30-2008, 21:37 | #8 (permalink) |
Member: 339548 Status: Offline Thanks Meter: 0 | in my case it was the rap or flash memory fault 4sure the lcd's ic wasn't the reason.i didn't touch it.if it was the phone should sounds or make emergency calls.i also couldn't got info from it. i rehotted the RAP/memory flash(twice.the first1 didn't work) and tried to flash it again without doin backups in manual mode.and done!now is doin well. try this if u had such a problem.hope it will help u. i'm gettin feelin that memory can be responible for that most than rap.(because i could do the check but couldn't get info from the piece) in case when your phone works good but gots no backlight (lcd/keyboard) u have to change ic shown in many threads/post on forum. |
6120 blink then off | khm050 | Nokia Hardware & Hardware Repair | 5 | 04-11-2011 14:36 |
Z140v blink then off | mobifone | QUALCOMM Models (3G) | 1 | 01-27-2010 17:14 |
6070 blu lcd and then off | .::ADNAN440::. | Nokia Hardware & Hardware Repair | 3 | 08-09-2009 14:39 |
6300 4 blink and then off | heror81 | Nokia Hardware & Hardware Repair | 17 | 03-06-2009 10:20 |
Siemens A65 blink then off | virgix | E-Gold Based Phones | 1 | 01-10-2006 19:01 |
