Old 11-19-2012, 12:22   #1 (permalink)
Member: 299440
Thanks Meter: 37
5630d need camera solution?
if have any one 5630d camera solution
ple give me
Old 11-19-2012, 19:49   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
first check d two vcam voltages at marked points , then let me know d result.
Old 11-20-2012, 06:13   #3 (permalink)
Member: 299440
Thanks Meter: 37
thanks for reply
we check the voltage at this point but there are not any volts
what to do ?
Old 11-20-2012, 10:58   #4 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
check in positive side of marked chipcap , other point is ground . if u messure in ground side of chipcap then not show any voltage . so double check .
both vcam voltages r controlled by two regulator (N1401 & N1402) . Rapuyama gives signal to these two regulator while camera on mode for supply vcam voltages .
tell me what was d prevoius condition of d set ? what action had u taken ? is it water damage ? give full details , also selftest result.
Old 11-20-2012, 12:19   #5 (permalink)
Member: 299440
Thanks Meter: 37
this is not water dameg board is clean
Old 11-20-2012, 13:20   #6 (permalink)
Member: 299440
Thanks Meter: 37
Phone type: RM-431 (Nokia 5630)
SW version: V ICPR82_09w36.3 22-09-09 RM-431 (c) Nokia
ApeCoreSw: 013.009
Imei plain:
Product code: 0574949
Battery voltage: 4637 mV, current: 121 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359350023140151
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 11-20-2012, 13:21   #7 (permalink)
Member: 299440
Thanks Meter: 37
in the self test all test is passed
Old 11-20-2012, 13:23   #8 (permalink)
Member: 299440
Thanks Meter: 37
if we test camera conf file with hti box give this eror
Failed to read DCC data.
Scanning DCC from EEPROM ...
DCC data is absent on EEPROM.
Camera Configuration data is empty.
Old 11-20-2012, 21:58   #9 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
ok , try to write camera dcc file . post result
Page generated in 0.20819 seconds with 10 queries
