Old 11-10-2009, 14:17   #1 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
7210C auto on whike insert battery
Hi Friends I have one nokia 7210C water damage set which is auto on while insert battery , after deep clean set working fine but red key not working.
can't turn off the set by pressing power key(red key)
Please guys help me to solve this problem.......
Old 11-10-2009, 14:31   #2 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.try it.
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 11-10-2009, 16:37   #3 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
1st clean ur bord as good as u can if same then try to rehot keypad ic if same then change keypad ic
Old 11-10-2009, 17:26   #4 (permalink)
mahbubalfa's Avatar
Member: 1003058
Originally Posted by ashad420 View Post
Bro.try it.
Sorry for worong post...
Old 11-10-2009, 17:37   #5 (permalink)
Member: 1151916
Thanks Meter: 10
probably not the machine is still there clean.so or key components of the corrosion.
repeated washing machine try it again until clean.
Old 11-11-2009, 21:29   #6 (permalink)
Member: 538022
Thanks Meter: 93
here solution
7210 c, d'ont power on and all power on key problem
rehot ,reball or change this crystal ic z2402
The Following 2 Users Say Thank You to AZZ14 For This Useful Post:
Old 07-05-2010, 13:05   #7 (permalink)
rawkiss's Avatar
Member: 997585
Thanks Meter: 17
WATER PROBLEM 7210 C . After cleaning water damage of nokia 7210c , my cell phone automatic power on when battery inserted and won't work red ( power button ) after getting phone started . Other keypad works fine , but doesn't power off. I tried to change the keypad flex but same problem . Please help me.
Old 07-05-2010, 13:27   #8 (permalink)
Member: 1338457
Thanks Meter: 31
brother change key pad ic near conecter and enjoy
Old 07-05-2010, 13:33   #9 (permalink)
ashokassag's Avatar
Member: 762520
Thanks Meter: 95
brother i think its keypas flux fluxproblem try to change with anothe one
sigmatel T33 auto power on when insert battery asif_ae Chinese Models & Cloned Phones 6 12-28-2008 15:58
sigmatel S3 auto power on when insert battery rk19801 Infinity-Box 5 12-28-2008 04:34
1100 ligts on when insert battery faisi Nokia Hardware & Hardware Repair 14 02-06-2007 05:23
3100 power ON itself inserting battery neppra Nokia Hardware & Hardware Repair 3 09-10-2006 19:26
motol7 automatic power on when insert battery! dung51mobile Motorola Hardware Repair 3 08-15-2006 19:02
Page generated in 0.22011 seconds with 10 queries
