5800 fbus cable pinout pls help pls if someone can help me, i need nokia 5800 fbus cable pinout, i've tried usb flashing but it stops at Pooling and tells me phone not found. Pls help, phone is working, its just security code, so i want to flash it to get rid of the security code. Pls help |
1 Attachment(s) this is ........................................ BR |
thanks alot for this. Will give it a try and post result Quote:
not work................................... MobilMan |
work ;) just adjust ur rx-2 pin use only 5 pin adjust ur cable for its pin then will work |
hi; help me please hi; help me please how to flash 5800 using usb cable. ? thanks |
thanks veery good resulta 100/100 working |
Tested 5 pins 7k5 resistor whit universal Fbus cable for Jaf. Unlock one whit DK box. Best Regards and thanks for help me. |
Could you say which cable do you use ? THe number write on the cable ? Thks |
7. Universal Fbus BB5_PCB-7 Support phone model: N78, 6210N (7k5) , E66, 5320D,5800 (7k5) Same cable to this phones. 7 if used ipmart fbus cables. BR. |
Hi.I have this cable : http://fonefunshop.co.uk/Unlocking/s...universal2.htm anyone unlock 5800 or n78 using this cable?? Thanks for help!~! |
