09-09-2010, 21:31 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: Nordic country Age: 53
Member: 77102 Status: Offline Thanks Meter: 6 | 5800 hangs with memorycard When I got a memorycard in my 5800 the phone starts up and show Nokia loggo, then it hangs. If I take out memorycard I can start the phone without any problems. What is the problem? /PA |
09-10-2010, 01:56 | #2 (permalink) | |
Junior Member Join Date: Aug 2010
Member: 1379642 Status: Offline Sonork: 12345 Thanks Meter: 0 | Quote:
- You can go to management applications, delete the most recent software installed to check out no. - Not then back up data then format the memory card. - If you still can not fix, you must reformat the computer only (remember Before you back up the data format and a bit of a fully charged battery, battery is tired halfway there) 1. Format machine, press (* # 7370 #) - This is considered the most popular format. From the standby screen press * # 7370 # machine will not ask if you want to format. After OK, the machine will ask you to enter codes. Now you enter the default Nokia CODE is 12345. If your alarm CODE enter not true, because you've accidentally changed the code or buy it second-hand computer has changed the default CODE. But you should not worry follow the latter two below. After the import is complete wait a few minutes it will complete format. 2. Format button machine with rule 3 (Call key (Green key) + * key + 3 key - First off you computer, keyboard and press the Call key (Green key) + * key + 3 key and power button with a time (so two people the same way, then simply press). All you hold the button on the screen to never of the phone is the new word Fomatting hand drop. If you do not try to do it again, how well is patience. 3. Format of the * # 7780 # - If for some reason, you must reformat but do not want to lose the programs installed, then you press the command: "* # 7780 #". This command means to restore the system but not to lose games and programs installed in your computer. ic solution is that instead memorycard | |
09-10-2010, 14:36 | #3 (permalink) |
No Life Poster Join Date: Oct 2007 Location: nigeria
Member: 601591 Status: Offline Thanks Meter: 86 | hello test another mmc card first bcos most of the mmc now is fake if not work open ur set and clean pcb but remember care for the mic dont let liquid enter it to avoid mic problem. |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
