Old 02-05-2009, 09:33   #1 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
5800 just vibrate only
i got brandnew 5800 with vibrate only..flashed with latest fw 11.0.009_v3.0 but problem is same..any solution?
The Following User Says Thank You to sharaz191 For This Useful Post:
Old 04-24-2009, 23:34   #2 (permalink)
Member: 494074
any solutsion????????????????????????????????????????? ??
Old 04-25-2009, 02:36   #3 (permalink)
Member: 164003
Thanks Meter: 25
flash the phone 2 the latest ver. and it will work ok tested with jaf
Old 04-25-2009, 22:41   #4 (permalink)
Member: 494074
i did the latest virsion but the problem still any new ?????????
Old 04-25-2009, 22:56   #5 (permalink)
Member: 756404
Thanks Meter: 28
5800
flash with latest version
Old 04-27-2009, 22:36   #6 (permalink)
Member: 494074
i did flash latetst virsion but the not sloved any new solution ???
Old 05-02-2009, 22:17   #7 (permalink)
Member: 756404
Thanks Meter: 28
5800 flashing
flash latest version by jaff by using usb cable in dead usb mode and send result ok
Old 05-03-2009, 09:09   #8 (permalink)
jasir_kp's Avatar
Member: 705281
Thanks Meter: 55
just rehot avilma..........
Old 05-04-2009, 06:14   #9 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
flash it by bead usb man bylatetst virsion 21.00.25
Old 05-06-2009, 15:11   #10 (permalink)
abcrino50's Avatar
Member: 68882
Sonork: 1577247
Thanks Meter: 111
if flash dont help u . u have to full erase phone then flash again but now u need to pay for rpl
Old 06-26-2009, 19:29   #11 (permalink)
Member: 735111
Sonork: safeer4u
Thanks Meter: 4
check battery connector and bsi line
Old 11-17-2009, 08:37   #12 (permalink)
themobileguy1's Avatar
Member: 1021573
Sonork: 100.1622854
Thanks Meter: 55
where is bsi line
and i try to flash
bt set is not booting
any solution 4 that
Old 11-17-2009, 09:04   #13 (permalink)
Member: 857624
Thanks Meter: 20
flash with latest version i am tested in v 31.0.101 this is new vwesion
5800 vibration only azharjamal Nokia Base Band 5 ( BB-5 ) 14 06-30-2010 09:33
5800 vibration only when powering on vijeeshkannur Nokia Base Band 5 ( BB-5 ) 0 02-15-2010 11:55
5800 dead just vibration anh help ! abcrino50 Nokia Base Band 5 ( BB-5 ) 4 05-27-2009 12:29
5800 just vibrate only sharaz191 Nokia Base Band 5 ( BB-5 ) 6 02-05-2009 13:47
5x 8850 vibrating problems vibrate only TheEckoMan Nokia Hardware & Hardware Repair 6 04-01-2002 05:21
Page generated in 0.19062 seconds with 9 queries
