04-16-2010, 12:28 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::5800xm lcd ok when connect cable but not ok with battery::.. |
The Following User Says Thank You to HUM For This Useful Post: |
04-16-2010, 12:42 | #2 (permalink) |
No Life Poster Join Date: Aug 2007 Location: world
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | check superdongle and simlock mostly superdongle and simlock invalid in5800xm when flash . repair sx4 and simlock area and flash with latest version then problem solved. |
04-16-2010, 12:49 | #3 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | Phone Type: RM-356 (Nokia 5800 XpressMusic) SW Version: V ICPR72_09w44.4 20-11-09 RM-356 (c) Nokia Imei plain: 35798803149437-5 Product Code: 0575374 ApeCoreSw: V 40.0.005 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357988031494375 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
04-16-2010, 13:59 | #6 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | i full flash with higer version but not on with battery only vibrate |
04-16-2010, 19:57 | #11 (permalink) | |
Junior Member Join Date: Mar 2010
Member: 1272012 Status: Offline Thanks Meter: 7 | Quote:
i have step by step solution for this problem 1. backup your Rpl & PM 2. reset with mx-key NPC after reset NPC phone is stert with contect service 3.now connect battery and chack phone in contect service or not 4.restor rpl then bus chack if not good 5.now you have latest version so downgrate your phone hope your problem solved br GSMDoctors | |
04-18-2010, 06:00 | #14 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,033 | Quote:
Can you make some test - like LCD and BT - ? - if not - then = again you have problems with APE part ... You have flashed with MX-Key ?... If yes - then you have problems with APE part - the latest MX-Key SW cannot handle correct APE flashing ... sorry to say that but it's tested more thet few times ... for best results - use Cyclone ( tested JAF and MT-Box ... without success or partially results after MX-Key damage ) to revive it ... Drop more info if you need to revive this phone ... WBR, DebeliaMark, BG P.S. in no one case - DO NOT ERASE phone via MX-Key, especially APE part ... | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
