Old 08-30-2007, 00:49   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::6020 blank display::..
i recieve 6020 water damage with no power, i clean the circuit but no0 power than i try on software, it gives error,so i reball flash ic and again connect on software now flashing complete,ui setting failed, but set is now on and show screen,but again i chk there is only blank display with white lights,now wat can i do?
Old 08-30-2007, 05:03   #2 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
Dear brother,
first of all you change the lcd and check the dispaly if problem is
then check this lcd way.
Muhammad Afzal Meo
Old 08-30-2007, 05:28   #3 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
full erase then flash again with new version,Good luck
Old 08-30-2007, 05:33   #4 (permalink)
Member: 283763
Thanks Meter: 102
flash latest version 100% ok if no contact me
Old 08-30-2007, 06:31   #5 (permalink)
tele-teknik's Avatar
Member: 64598
Thanks Meter: 54
Originally Posted by meo786pk View Post
Dear brother,
Muhammad Afzal Meo
change upp...Good luck
Old 08-30-2007, 11:25   #6 (permalink)
totalmanish's Avatar
Member: 336192
Thanks Meter: 53
just apply white paste heat alittle with ****er especially flash ic and flash `also use 128 upp file 100% ok
Old 08-30-2007, 12:02   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
thnx 4 ur replies i will try and post results.
Old 09-25-2007, 17:20   #8 (permalink)
mizancoxr's Avatar
Member: 544628
Thanks Meter: 166
Dear brother,
Muhammad Afzal Meo
so thanks bro.............................................
..::6120c blue display::.. HUM Nokia Hardware & Hardware Repair 11 03-02-2010 14:04
..::k750 calling is ok but blank display::.. HUM Sony Ericsson Hardware Repair 5 10-05-2008 23:42
..::6020 sim batt,memory full::.. HUM Nokia Hardware & Hardware Repair 3 09-02-2007 22:45
..::n70 on white display::.. HUM Nokia Hardware & Hardware Repair 5 05-12-2007 16:10
Page generated in 0.20458 seconds with 10 queries
