08-01-2006, 14:41 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | 6020 flashing ok but dead waiting.......... thanks |
08-01-2006, 14:51 | #2 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: gavni
Member: 188646 Status: Offline Thanks Meter: 76 | 6020 dead Quote:
first u chack mob shotig after write flash with latesvertion file when formet and ui siting ok thanks............. | |
08-01-2006, 15:15 | #3 (permalink) |
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | after writing flash phone does not go in local mode...... and then this is not possible to do ui settings............. i flash it with 4.01............ |
08-01-2006, 22:03 | #6 (permalink) |
Junior Member Join Date: Aug 2006 Location: india
Member: 323176 Status: Offline Thanks Meter: 0 | U Dont **** The If Ic Because U Had Flashed.it Means That The If Ic Is Ok.so U Have Only Two Choices To Rectifi The Problem.the One Is Changing Flash Ic Other Is Changing Processor. Today I Ready The Same Problem By Changing Processor |
08-02-2006, 02:23 | #7 (permalink) |
Insane Poster Join Date: Dec 2004 Location: Adelaide Australia Age: 39
Member: 96184 Status: Offline Thanks Meter: 6 | check the energy managment values before you heat the board. if the battery voltage level is really high then you need to correct by copying the em values from a working 6020 and write to your faulty 6020 using phoenix. |
6020 flashing ok but normal mode failed | rinku24 | Nokia Hardware & Hardware Repair | 6 | 11-29-2008 07:48 |
3200 (RH-30) Flash Ok but Dead | goga3000 | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 04-25-2006 19:35 |
3310 dead can flash ok but dead | mobilemafia | Nokia Hardware & Hardware Repair | 12 | 06-02-2004 00:06 |
