10-03-2006, 13:56 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Philippines Age: 64
Member: 69911 Status: Offline Thanks Meter: 69 | 6020 local mode thanks... |
The Following User Says Thank You to edpr_0507 For This Useful Post: |
10-03-2006, 18:19 | #2 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 41
Member: 108629 Status: Offline Thanks Meter: 16 | Check bsi line capestor locaion and remove it. Process Use multimeter, connetc one point with bsi point(mid point of battery con) and with other wire of multimeter search it on board where multimeter shows full diffelection with capestor remove this capestor and set will be ok This process will work for u for all sets |
07-22-2007, 05:57 | #6 (permalink) |
Major Poster Join Date: Jun 2005 Age: 51
Member: 154049 Status: Offline Thanks Meter: 2 | 6020,3220,7260 local mode http://rapidshare.com/files/44294198...ution.rar.html sir try this it works 100% teted today 7/22/07 b,r bfs_oragon |
08-23-2007, 09:12 | #9 (permalink) |
Freak Poster Join Date: Aug 2007 Location: just learning Age: 45
Member: 560754 Status: Offline Thanks Meter: 289 | Bro,if u try all this and the problem is not solved try 2 full erase with ur Box and flash with the new version,if the problem still same try 2 replace Uem ic...Good luck!!! |
08-23-2007, 13:29 | #10 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: INDIA
Member: 350571 Status: Offline Thanks Meter: 920 | Quote:
08-23-2007, 16:49 | #13 (permalink) |
No Life Poster Join Date: Oct 2006 Location: U A E
Member: 364745 Status: Offline Thanks Meter: 719 | 1 first try full calen pcb 2 try solution archit RAJ NOT Solved so check uem problem rebal uem i hope it will b work and problem s/w .................. ..::Mr Fone::.. |
03-13-2008, 17:05 | #15 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: Here
Member: 39196 Status: Offline Thanks Meter: 126 | Quote:
good work thannnnnnnnnnks. | |
Help for 6020 local mode | chronic | Nokia Hardware & Hardware Repair | 4 | 04-17-2009 00:08 |
6020 local mode | blinet | Nokia Hardware & Hardware Repair | 7 | 04-26-2006 15:51 |
Test mode, Local mode Normal mode | royke | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 08-13-2002 11:33 |
