Old 04-01-2007, 13:19   #1 (permalink)
Member: 234790
Thanks Meter: 4
6020 powers on when u insert battery
hi guys
i have nokia 6020 powers on as soon as u insert the battery
i checked the power press but its ok
have u any solutions?
thnx in advance
Old 04-01-2007, 13:36   #2 (permalink)
Member: 340158
digitalpower
you can change the switch which is bad it will work.
Old 04-01-2007, 17:06   #3 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
First You Change The Switch And Check It If Not Than A Small Black Component Below The Switch Sometimes Short With Ground Due To Some Circumstans
Old 04-04-2007, 08:53   #4 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
you have to change the switch first.
Old 04-04-2007, 20:33   #5 (permalink)
Member: 374225
Thanks Meter: 41
check for shorting by multimeter by putting them to batt connector if its showing short then might be PA is faulty but is batt connector doesnt show shorting then somewhere prob in ur power ways
Old 04-05-2007, 05:43   #6 (permalink)
Member: 350571
Thanks Meter: 920
Originally Posted by hany elsaghir f View Post
hi guys
thnx in advance
clean the board well
sigmatel T33 auto power on when insert battery asif_ae Chinese Models & Cloned Phones 6 12-28-2008 15:58
1600 powers on when u insert te battery hany elsaghir f Nokia Hardware & Hardware Repair 2 01-07-2008 00:52
motol7 automatic power on when insert battery! dung51mobile Motorola Hardware Repair 3 08-15-2006 19:02
v200 automatically power on when u connecte battery gbada Samsung Hardware Repair 1 01-29-2005 16:01
sagem mw3026 powers on when you insert batery bruce77 Infineon C16X M51 & ARM7 M52 BASED 0 01-29-2005 03:44
Page generated in 0.16485 seconds with 9 queries
